Raw Water Heat Exchanger teardown, Westerbeke - Page 2 - SailNet Community
 3Likes
post #11 of 20 Old 09-04-2018
Re: Raw Water Heat Exchanger teardown, Westerbeke
At some point in time some/many of the Uni Westy factory HXs were deemed too small and a larger size was recom3nded.
I have a new original size as a spare and the larger working.
RegisteredUser is online now
post #12 of 20 Old 09-05-2018
One of None
deniseO30's Avatar
there are still allot of tugs and trawlers and maybe even some larger ships that use Keel coolers for their engines, of course they'd be much larger than the little ones you see on your little Refrigeration units [emoji41]
My last project!
deniseO30 is offline
post #13 of 20 Old 09-05-2018
Learning the HARD way...
eherlihy's Avatar
Originally Posted by Lazerbrains View Post
This makes me appreciate my Beta Marine engine - the heat exchanger tube stack simply slides out for cleaning.
As you should.
Realize that the Beta and the Universal/Westerbeake are both marinized Kubota tractor engines. Most of the bronze Universal engines are now over 30 years old (mine is 32) and are still going strong. These were the best solution available at that price at that time (early to mid-1980s). That's why Catalina, Ericson, O'day and other manufacturers used them in their boats.
If I were to re-power from my M25 tomorrow, I would look closely at the Beta 25.
RegisteredUser likes this.
USCG Licensed OUPV Captain, US/Sailing BKB and ASA 101/103/104/105/106/114/118 Instructor - Also ABYC certified in Marine Electrical Systems,
eherlihy is online now
post #14 of 20 Old 09-05-2018
Thought I'd mention an idiocintxrisy of keel coolers over H EX . The water pump under the thermostat is not positive displacement and at a long slow idle may not be circulating enough down and around.. Temp alarm and an eye on gauges a good thing. That be good with air lock in a regular hx setup too. Last time I looked, most of the fishing boats had keel coolers.
Capt Len is online now
post #15 of 20 Old 09-05-2018
Originally Posted by eherlihy View Post
As you should.
Realize that the Beta and the Universal/Westerbeake are both marinized Kubota tractor engines. ...
My Westerbeke has a Mitsubish block, I have not heard of a Westy with Kubota block.. yet.
SVTatia is offline
post #16 of 20 Old 09-05-2018
eherlihy's Avatar
Westerbeake merged with Universal resulting in Universal/Westerbeake.
With over 75 years experience with marine propulsion engines, it's easy to see why Universal marine diesel engines by Westerbeke have led the way in auxiliary marine propulsion. Exclusively designed for marine applications, our Universal boat engines represent a breakthrough in marine diesel engine compactness, quietness, and reliability. Used by the most prestigious auxiliary sailboat builders, thousands of Universal diesel engines have been installed in boats for pleasure, commercial and government use.
Here is a Westerbeake / Universal (or Universal / Westerbeake) that is a Kubota block;
https://westerbeke.com/category/M-25...D#mainoverview
It is based on the Kubota D950
post #17 of 20 Old 09-05-2018
Dirt Free
boatpoker's Avatar
Westerbeke marinized diesels from several manufacturers and has gone to great lengths to make small changes so that OE parts will not fit, they have also gone some length to hide what those engines are.
Good marketing - predatory parts pricing.
i.e. They use a standard Sherwood pump and modifiy the mounting base on the pump to fit their own mount .... totally unecessary but they get to charge $400 more than the Sherwood version. I went through this last week and modified the Westerbeke mount to fit the Sherwood version. It took quite an effort to find the right Sherwood pump since Westy changed the part number and omitted their base modification from the drawing in their parts manual ............... PRICKS !
MastUndSchotbruch likes this.
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is offline
post #18 of 20 Old 09-05-2018
Sorry eherlihy, if it ain't red it ain't a Westy!
+1 boatpoker, exactly right - and I have the Mitsu parts manual for my W30B3 just in case and it was a pain to find out which model it was. But I give them a lot of attention and have never had a problem with these engines, 10 years previous boat, 2K hours + 4 years current @ 900.... knock on wood.
SVTatia is offline
post #19 of 20 Old 09-13-2018
Hi,
I can't send you a PM because I haven't posted enough but if you still have the heat exchanger I'd take it. I'm in East Falmouth and I assume you can PM to me and I'll respond. Thanks!
vermontosea is offline
post #20 of 20 Old 09-14-2018
eherlihy's Avatar
PM Sent - I will be in East Falmouth TOMORROW so I can deliver!
Heat Sheild for Heat Exchanger Philzy3985 General Discussion (sailing related) 2 12-23-2015 09:32 PM
Westerbeke 40 heat exchanger repair pinayreefer Gear & Maintenance 0 07-06-2012 03:37 PM
Westerbeke 4107 heat exchanger question carley Diesel 3 06-13-2012 08:29 PM
Water Heater heat exchanger hook up question EO32 Gear & Maintenance 36 08-25-2008 10:06 AM
Heat Exchanger for Westerbeke T37Chef Gear & Maintenance 8 08-13-2007 09:00 PM
