Exhaust system - SailNet Community
 1Likes
  • 1 Post By TomMaine
post #1 of 6 Old 09-19-2018 Thread Starter
Location: On my boat, currently moving around the east coast US
Exhaust system
I think this might be a silly question...but I don't know what I don't know....
Is there any reason the high point of the exhaust (post muffler) to the outlet can't be a shallow slope? I am redoing my exhaust system (and engine, and...) and the existing system goes from muffler, up a bit, over the fuel tank, up further, and to a high point that comes close to straight down to the exhaust thru hull - essentially irregular but shallow slope from muffler to high point, to steep slope to exhaust
I'm thinking of changing the system to a vetus NLP50 that would go up a sharper slope directly to a Vetus NLPG50 and then to a shallow slope to exhaust thru hull.
I don't see a reason moving the steep slope from before the high point to after would matter, but I thought I'd ask. The high point would be very close to the same height and same distance from the center line.
Cruising on my CS36T
reduc is offline
post #2 of 6 Old 09-19-2018
bell ringer
Don L's Avatar
Re: Exhaust system
as long as there still is a high point and hose volume between the high point and the engine isnt so much that it can back fill water back to the engine is should be fine
when I researched exhaust for installing my generator I found some great articles on the web, you shoud give a search
Don't blow air up my rear, be useful and blow it at the sails!
Don L is online now
post #3 of 6 Old 09-19-2018
One of None
deniseO30's Avatar
Re: Exhaust system
I'm pretty sure the water lift muffler (assuming here) should be the only "trap" in the whole line.. the inverted loop and water injection are pretty well established and dependable design elements in Marine exhaust.
https://www.betamarinenc.com/exhaust-design/
West marine tech page
My last project!
deniseO30 is offline
post #4 of 6 Old 09-19-2018
Re: Exhaust system
' would go up a sharper slope directly to a Vetus NLPG50 and then to a shallow slope to exhaust thru hull.' Con,, A long slope to outlet can allow surging in the hose when stern lifts to following sea and the muffler can only hold so much. Consider a gate valve at the transom and a means of draining the aqua lift. (not necessarily at the bottom) Both good to have ,imo. A loop at the spitting end can reduce ingress from ocean but any water left in hose on shutdown falls to muffler Is it big enough and can you drain it if something fails (Anti s vent?)
Capt Len is online now
post #5 of 6 Old 09-20-2018
TomMaine's Avatar
Re: Exhaust system
I was limited by the cockpit sole and aft deck (my highest point) in my installation. I made sure I installed a waterlift muffler with plenty of volume for the drain back of my 2 3/8" exhaust hose(easy to calculate).
In theory, the exhaust hose could drain back it's entire volume in seawater, at engine shut down.
In practice, I've found surprisingly little seawater (opening the drain to actually see), is in the line at shut down.
The flaw in a system like this is the possibility of cranking the engine so long, you fill the system with seawater. Again in practice, I don't think the battery would hold up long enough to pump the (a very small amount during cranking) amount of seawater needed to fill my oversized waterlift muffler and hose to above the riser, and into the engine.
My exhaust outlet is 12" above the waterline, with the high exit bend in the hose, 12" above that outlet. I'm not worried about backflow into the system. It's worked better than I expected after a couple seasons. My raw water has a vented loop 12+" above the riser which is wrapped in exhaust insulation.
Hope this helps.
RegisteredUser likes this.
Tom Young sailing a 1961 38' Alden Challenger, CHRISTMAS out of
Rockport, Maine.
'I'd have written a shorter post, but I didn't have the time', Mark Twain.
TomMaine is online now
post #6 of 6 Old 09-21-2018
Re: Exhaust system
Vetus have a formula to calculate the water volume between water trap and high point after the trap. Use this to calculate if the water trap is large enough.
knuterikt is offline
Original copper exhaust system - any good? CascoBayP30 P30 2 01-23-2012 07:18 PM
Exhaust system replacement using mostly Trident? Pub911 Gear & Maintenance 4 05-10-2010 08:06 AM
Exhaust System leaks davidpm Gear & Maintenance 2 09-08-2008 09:50 PM
Marine Exhaust System Literature I-33 Gear & Maintenance 8 04-24-2007 02:00 AM
Exhaust System Repair skhorleb Atomic 4 7 12-06-2006 01:03 AM
