Rebuilding the Volvo MD7A, Part II - SailNet Community
post #1 of 5 Old 03-29-2019 Thread Starter
Marine World Classifieds
Ze'K's Avatar
This is the final installment of my Volvo MD7A rebuild write up. I've been starting it up daily for 3 days now so far, plan to keep running her an hour every day just to break her in.
Ze'K is offline
post #2 of 5 Old 03-30-2019
Re: Rebuilding the Volvo MD7A, Part II
Well done that man !
I have the MD17c.
Just finished a barrel replacement.
Do not let your motor freeze !!!
I did !!!!
Rockter is offline
post #3 of 5 Old 03-30-2019 Thread Starter
Ze'K's Avatar
I have the MD17c.
I did !!!!
Thank you sir. You are absolutely correct. I realize tho that it's a never ending saga of diligent maintenance and care to keep her running well. It's just the beginning 🙂
Ze'K is offline
post #4 of 5 Old 03-30-2019
With regular oil changes for both engine and gearbox, the motor and gearbox can be very long-lived.
Remember to make all your gear-changes at idle and keep checking the gearbox oil level.
For years, my old gearbox held oil with no problem, then one afternoon the gearbox seal failed and the oil was plastered all over the engine room in a big line of oil splash. It sounded a bit clunky and I checked it.
Keep a final drive gearbox seal or two handy. They are about $6 (not from Volvo !!!). If i remember, it is a 100x120x12 mm seal (ID, OD and thickness).
If the seal leaks, when you fit the new one, knock it in a wee bit further than the old one, otherwise the new seal rides on the same wee rust pits as the previous one and leaks again.
In very cold weather, run a fan heater under the air filters to assist in the first start.
Be careful with scaling of the coolant entry ports in the head. They can scale up given time, then it overheats and scores the pistons. It will not happen in freshwater but can be a problem in the salty tropics.
I opened the removable side panels of the engine compartment so i could keep checking the engine. I run an open engine compartment. It's a bit noisy but I guess an older engine does need constant checking.
Rockter
Rockter is offline
post #5 of 5 Old 03-31-2019 Thread Starter
Ze'K's Avatar
Rockter
Thank you for the advice. I already have encountered a failure and the 37 mm plug in the heat exchanger is leaking so it's off to the machine shop. They're fabricating a piece for me. I should be ok after this.
Ze'K is offline
Rebuilding the Volvo MD7A Ze'K Gear & Maintenance 13 04-01-2019 05:31 AM
Volvo/Penta MD7A paulinet. Diesel 8 09-12-2014 11:25 AM
Volvo MD7A Alternator jthomas5 Gear & Maintenance 16 12-15-2008 08:45 PM
Volvo MD7A-1977 Neicy Gear & Maintenance 6 11-09-2005 04:07 AM
Volvo MD7A BertV Gear & Maintenance 4 07-14-2003 08:59 AM
