Replacing transmission oil cooler - SailNet Community
post #1 of 16 Old 2 Weeks Ago Thread Starter
Hey guys,
My tranny oil cooler is due for replacement. I was wondering before I pull the lines from the cooler/tranny, how much oil should i suspect to see come flowing out?
I am planning to pull the cooler from its mounts, remove the raw coolant lines which appear to run to a pump which is hooked to the heat exchanger(?), then remove the oil cooler lines and bring into Fisheries Supply to get a replacement.
I just am worried regarding how much fluids I should suspect to see? I have limited working space, so I'd like to get a small container in there, but maybe a **** ton of absorbent pads and towels would be better?
chowdan is offline
post #2 of 16 Old 2 Weeks Ago
Re: Replacing transmission oil cooler
Limited loss of oil. but the cooling water will drain .If raw water cooled shut off the thruhull.
Capt Len is online now
post #3 of 16 Old 2 Weeks Ago Thread Starter
I believe this isn't hooked up to raw water, rather it is hooked to heat exchanger, though I am not 100% sure. Quick looks indicated that.
Would I disconnect the oil hose from the tranny first, or from the exchanger first? I suspect the exchange would come first as i could then hold the hoses upward to prevent loss.
chowdan is offline
post #4 of 16 Old 2 Weeks Ago
Dan-
Remember that for a hardline or a rubber tube, you can usually stick a golf tee, sharpened pencil, or other object (even a foam ear plug) into the end of the hose, to stop fluid from draining out.
Somewhere in the manual for the transmission it will state what the entire capacity is, that's the max that can come out, although draining any one point usually won't get you that much.
hellosailor is offline
post #5 of 16 Old 2 Weeks Ago
Master Mariner
capta's Avatar
I don't like saying negative things about good companies, but I have not been able to find a single price on the Fisherman's Supply website that is anywhere near as inexpensive as most other sites. Just a word of caution.
There is a huge range of prices on oil coolers and the like and if you are certain you need to replace it, rather than taking it to a radiator shop for repairs, I'd certainly take the time and shop around.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #6 of 16 Old 2 Weeks Ago
Sometimes fisheries supply does have a slightly better price...depends on the item
RegisteredUser is online now
post #7 of 16 Old 2 Weeks Ago
I have patronized them for years. Their web pricing shows "list" and when you place an order you see the actual discounted price. It's their store policy. Not bad or good, but different from some other companies.
1988 Olson 34, by Ericson Yachts.
Sail # 28400
Betamarine 25 (new 2018)
RCYC, Portland, Oregon
olson34 is online now
post #8 of 16 Old 2 Weeks Ago
Old soul
MikeOReilly's Avatar
I had to replace my cooler last season after the water side sprung a leak. When I removed the lines there was very little oil — it had already drained back into the tranny. I unhooked from the cooler and did as you suggested to drain any residue back down.
As Len says, if it’s raw water cooled (mine was) make sure your seawater intake is closed. Or do as I did, and do the job on land during haul out.
I did find quite a range of prices when I was looking to buy a new one. I mentioned it to my dock mate, an old Newfoundland fisherman. He told me not to bother, and then he just gave me one he had on hand.
Salt of the earth.
Why go fast, when you can go slow.
BLOG:
MikeOReilly is online now
post #9 of 16 Old 2 Weeks Ago
Dirt Free
boatpoker's Avatar
I recently replaced my gear fluid cooler as it had sprung a leak. I spent quite a few hours building a new mounting location for it as it partially blocked other
items that needed more regular maintenance.
Proud of my work I sat back and it dawned on me..... my HT6-354 Perkins didn't have one and I put 20,000 hours on that boat. My TAMD60B didn't have one and I put 6,000 hours on that boat. Now those are big heavy duty diesels. If their tranny's didn't need cooling why should this puny little 55hp Westerbeke ?
PS. The Perkins had the exact same transmission as my little Westerbeke. I am going to seriously look into removing this cooler altogether. I don't think it was OE.
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is online now
post #10 of 16 Old 2 Weeks Ago
Master Mariner
capta's Avatar
Interesting.
I'd say it's a pretty bad policy because if I had known they were even halfway competitive, they might have thousands of my dollars that have gone to companies that don't have that policy.
capta is online now
Transmission Oil Cooler set up? Questions Ocean Cruising Gear & Maintenance 12 06-04-2018 10:23 PM
Removing Yanmar 4JH2E oil cooler bhcva Gear & Maintenance 0 09-29-2017 10:08 AM
oil cooler for a perkins 4.236 skibum54 Diesel 0 03-19-2013 06:08 PM
Perk 4.108 oil cooler fitting nimbusgb Diesel 3 08-25-2010 08:23 AM
transmission oil for diesel engines pegasus1457 Gear & Maintenance 7 10-25-2007 12:18 PM
