Torque Spec for Yanmar Injectors? - Page 2 - SailNet Community
post #11 of 19 Old 4 Weeks Ago Thread Starter
Re: Torque Spec for Yanmar Injectors?
Well I opened up the inspection cover and the inside didn't look that bad, though the float had some green slime on it. The fuel pickup is on the opposite side of the tank and I don't know how one would be able to inspect it, much less clean it out.
glossa is offline
post #12 of 19 Old 4 Weeks Ago
That green slime is algae, otherwise known as diesel sludge. It grows in diesel fuel when it has been contaminated by water (it takes just a tiny amount of water). It can block the fuel pump pick-up. Get a bottle of Stanadyne additive and add it to the tank. Then top it off completely with fuel.then run it for a while.
SeanM26 is online now
post #13 of 19 Old 3 Weeks Ago Thread Starter
So I bypassed the fuel tank and it still only revs up to 1400 RPM.
I then started the engine and loosened the flair nut to each injector, one at a time. There was no change in idle when I loosened the nut on the third injector. Some fuel came out when I loosened the nut.
So I suppose that means I have a bad injector, which is a surprise because the shop tests them after being re-built. I will probably call the shop in the morning but to rule-out the pump, I should probably swap two of the injectors and see what happens.
glossa is offline
post #14 of 19 Old 3 Weeks Ago Thread Starter
So I swapped the # 2 and 3 injectors and when I re-did the test from my last post, cyllinder 3 still doesn't fire. There is definitely fuel getting to the injector; I could tell when I cracked the nut.
I guess that leaves the pump? That makes no sense. It worked fine before I pulled the injectors the first time.
Running out of ideas.
glossa is offline
post #15 of 19 Old 3 Weeks Ago
Is it mechanical injection? Is the timing off?
post #16 of 19 Old 3 Weeks Ago Thread Starter
I found the problem but now the original problem is back.
When I removed the injectors, I tried disconnecting the # 3 injector line from the pump. The flare nut threads onto a sleeve that threads into the body of the pump. When I tried to loosen the flare nut, it wouldn't break free from the sleeve; instead, it backed the sleeve off by about 1/16th of a turn. I had forgotten. I tightened it back up and tightened the clamp that holds the sleeve in place. Based on the diagram, there's a lot of little pieces held in place by that sleeve, so it's sensitive to small movements. I started it up and it idles faster and revs up under load.
However, when I rev it up, there's once again quite a bit of smoke coming out the exhaust. It's definitely un-burnt fuel. So it seems like having the injectors rebuilt didn't cure the problem.
glossa is offline
post #17 of 19 Old 2 Weeks Ago Thread Starter
We took the boat out yesterday for the first time since my last post. Initially there was smoke coming from the exhaust but it went away after about five minutes, I suppose because the engine reached operating temperature. The smell of the smoke was different this time; it smelled more like burnt oil than unburnt fuel.
For now, the problem seems to have went away so perhaps it was the injectors. This exercise taught me how touchy (though reliable) mechanical fuel injection can be. It might be worth while to have the injector timing checked and for that matter, check valve clearances.
glossa is offline
post #18 of 19 Old 2 Weeks Ago
So...residue burning out.
Now keeping a watch on it.
Progress....
RegisteredUser is online now
post #19 of 19 Old 2 Weeks Ago Thread Starter
I think you're right about the residue. It could have been un-burnt oil that got past the piston into the combustion chamber.
My father-in-law, (a tug mechanic), thinks that I probably had an internal leak inside the injector pump for that cylinder. It was probably caused by the sleeve not being fully seated into the pump body.
glossa is offline
Torque plus Angle Torque specs aa3jy Gear & Maintenance 0 11-01-2018 11:15 AM
Yanmar 4JH3-HTE, -DTE Injectors IStream Diesel 2 06-07-2016 01:13 PM
Cleaning my Yanmar injectors? Dave Montgomery Diesel 43 06-15-2014 01:01 PM
To torque or not to torque davidpm Gear & Maintenance 22 11-15-2009 11:37 AM
Torque spec for Universal M4-30 Damper Plate? Pub911 Gear & Maintenance 0 03-04-2009 09:52 PM
