Fuel lifting pump making noise when first starting engine - Page 2 - SailNet Community
 14Likes
post #11 of 23 Old 05-10-2019
Master Mariner
capta's Avatar
Re: Fuel lifting pump making noise when first starting engine
Originally Posted by krisscross View Post
Yes, its a NAPA pump that PO installed between the Racor filter and the injection pump. Any idea what fuel delivery pressure is needed there? I would like to have a backup and guy at NAPA tells me I need to know that. I have read somewhere that it’s about 6 to 8 psi.
It's not about pressure at that point in the system, just GPH. Obviously, your pump must pump enough fuel for the diesel to run.
We on sailboats don't have much problem with even the smallest pumps rated by GPH but imagine a motor vessel using 75 to over 100 GPH per engine. That's when electric fuel pumps start getting expensive.
krisscross likes this.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #12 of 23 Old 05-10-2019
Master Mariner
capta's Avatar
Originally Posted by wsmurdoch View Post
For a replacement pump, spend some quality time on the Walbro fuel pump web site. https://www.walbro.com They make USCG approved marine fuel pumps and are the standard Many people sell them.
Bill
If I was running a gas engine, I'd certainly agree with you, but on our small diesels where ignition protection is unnecessary, the cheap ones seem to do just fine.
capta is online now
post #13 of 23 Old 05-10-2019
Capta is right.
Im outta this one....
RegisteredUser is online now
post #14 of 23 Old 05-11-2019
Automotive technician here; I recommend my customers avoid NAPA parts if at all possible. If it fails in a car, no big deal. Boats are not cars.
Also, a failed diesel lift pump can cause the injection pump to fail.
Minnewaska and krisscross like this.
SeanM26 is offline
post #15 of 23 Old 05-13-2019
Cassidy's Avatar
Typically a Yanmar has a fuel bypass that sends excess fuel that the engine doesn’t need to run, back to the tank. Well, at least the 4-cyl ones do, no reason to think the smaller ones are different.
So if the engine switch is on and the engine isn’t started, the pump you describe will continue clicking interminably as the fuel cycles back to the tank. These pumps click each time they deliver fuel, yours may click more frequently while the engine runs as a result of the through flow system.
I installed a diesel flow pump normally fitted to a Ford Explorer, pumps adequate volume for a 4JH4E and gently buzzes in the background. The downside is that the fuel is warmed by the through-flow and brings the temperature of the whole fuel tank up. I haven’t had problems yet but I often wonder about condensation, diesel bug and all those other horror stories.
Cassidy is offline
post #16 of 23 Old 05-13-2019
overbored's Avatar
the Yanmar does have a return line on the 4 cylinder and smaller engines but it is from the high pressure injectors and not the lift pump side of the injection pump so it only returns fuel when the engine is running. the reason the engineers have the fuel return back to the fuel tank is to cool the excess fuel that is coming back from the hotter fuel injectors. most Yammers have a mechanical engine driven lift pump and really don't need an electric lift pump unless the tank is placed to low in the system to meet the Yanmar requirements.
Capt Len and krisscross like this.
"GOLD RUSH" PRINDLE 16
overbored is online now
post #17 of 23 Old 05-13-2019
A thought... GMC's with unit injectors pump an immense amount of fuel back to the tank to cool their injectors,Little engines do the same but more discreetly. If your system has a short closed loop to save running a return line back to tank any heat or bubbles or crud stays in the loop
Capt Len is online now
post #18 of 23 Old 05-13-2019
Master Mariner
capta's Avatar
lol Well you see, that's the difference between us marine engineers and you Automotive technicians. Whereas you've got to go buy a replacement, we've got one or two spares stuck away in a drawer somewhere and can make the change before you've got your order into NAPA guy.
Two completely different mentalities; sadly, we don't have a NAPA store out there on the briny. lol
capta is online now
post #19 of 23 Old 05-14-2019
Get a Facet fuel pump. https://www.facet-purolator.com/ They usually last the life of the engine. I like the Posi-Flo and Gold Flo pumps. A cheap $20 backup isn't a bad idea though.
kmacdonald5 is offline
post #20 of 23 Old 05-14-2019 Thread Starter
krisscross's Avatar
Just bought a replacement pump to have as a spare. It’s a Facet pump. About $85 at NAPA.
Thank you all for your help. As always, very useful. Best sailing forum I know.
Plato
krisscross is online now
Electrical wires inside mast making much noise akin_alan Gear & Maintenance 19 07-07-2018 01:17 AM
Fuel Pump Noise BristolTucker Diesel 13 05-21-2015 06:38 PM
Fuel consumption vs. speed vs.noise wannabsailor General Discussion (sailing related) 3 02-07-2014 10:49 PM
Engine/Drive Train Noise dinkum1 Atomic 4 1 11-29-2006 01:52 AM
Engine/Drive Train Noise dinkum1 Bristol 2 11-18-2006 09:11 PM
