How much oil - SailNet Community
 3Likes
post #1 of 16 Old 05-11-2019 Thread Starter
How much oil
Just did a transmission oil change on a yanmar 2gm20f. Have owned the boat for 2 years Pearson 303 1986.
Took out 540ml oil the required amount is 250ml for this transmission. I did check the oil level in the transmission several times and it was high on the dip stick. Should I put in the 250ml or put in what I pulled out?
thumper53 is online now
post #2 of 16 Old 05-11-2019
JimsCAL's Avatar
Re: How much oil
Put in enough so it's at the full mark. If your 2GM is like my 3 GM, the mark is a groove on the rod attached to the fill fitting.
S/V First Tracks
1985 Cal 33-2
JimsCAL is online now
post #3 of 16 Old 05-11-2019
Check to learn if level should be read when pushed in or just flush/top of hole.
Common mistake
RegisteredUser is online now
post #4 of 16 Old 05-11-2019 Thread Starter
Re: How much oil
Thanks you do not screw it in to get the reading.
Just wondering if there may have been a reason to have put in so much.
I put in 300ml little above the mark.
post #5 of 16 Old 05-11-2019
They require so little that its easy to overfill
post #6 of 16 Old 05-11-2019
Master Mariner
capta's Avatar
Re: How much oil
I wouldn't put even a ¼ teaspoon more oil than is recommended. Stick with the manufacturer's level and you should be fine. After all, some pretty smart folks designed your transmission to work with your engine and on a boat, so second-guessing them just does not make any sense to me.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #7 of 16 Old 05-13-2019
Re: How much oil
The excess oil may have been put in for storage. It's common to overfill to cover all the gears/plates and protect against corrosion, but it should not be run that way.
Jeanneau 54DS
Minnewaska is offline
post #8 of 16 Old 05-13-2019 Thread Starter
Re: How much oil
Thanks, that makes sense as to how the oil got there. I was thinking it may have been done due to the angle of the trans. and I needed to put back in what I took out. So would you worry about the extra 50ml or just run it for a few hours change again, and put in the required 250ml? The plug vent is clear.
post #9 of 16 Old 05-13-2019
Re: How much oil
Confusing question. Why not just fill it to the Full line on the dip stick.
Jeanneau 54DS
post #10 of 16 Old 05-14-2019
SanderO's Avatar
Re: How much oil
A few questions about oil.
What does over filling do? presumably harm... Underfilling seems like there would be inadequate lubrication.
Isn't there more volume in the engine (and the transmission for oil than the oil required?
Although I don't service my car... done by dealer service department... I don't recall any regular oil changes for the transmission. Tranny doesn't seem to consume oil...(the way engine does)... Why change it? Does it become contaminated? What is the grade of tranny oil determined by?
pay attention... someone's life depends on it
SanderO is online now
How Much Wind is too much Wind weephee General Discussion (sailing related) 14 09-07-2011 10:34 AM
video ads are too much -- to agressive -- to much a pain in the .... Bene505 Announcements and Suggestions Box 4 10-08-2009 04:45 PM
how much is too much wind jimspafford Seamanship & Navigation 27 08-24-2007 08:22 PM
How much draft is too much? lmitchell General Discussion (sailing related) 10 11-10-2006 11:47 AM
How much is too much? mikeandrose Boat Review and Purchase Forum 17 04-08-2006 05:35 AM
