Broke two V-belts - Page 3 - SailNet Community
 1Likes
post #21 of 25 Old 06-03-2019
Re: Broke two V-belts
Insure that the bolt that holds the alternator dosent have misplaced washer/spacerwhich moves it forwd or aft a bit
Capt Len is online now
post #22 of 25 Old 06-03-2019 Thread Starter
I was hoping there would be a small spacer that could be adjusted, (it would have to be a thin washer and as mentioned that would only line up the outside of the pulleys) but there is none.
However, this time my "new" spare belt will keep its Yanmar line code label so I know it is a new one!
thanks,
CapnRon47 is offline
post #23 of 25 Old 06-03-2019
"The install does not look to bad, but probably requires an impact wrench to remove the alternator pulley."
We had a similar problem changing a pulley. Took the alternator to a local gas station, told the mechanic "This is from a boat, not a car. We couldn't bring the whole boat in, but could you swap out this pulley?"
I don't remember if he asked $5 or $10 but it was way simpler than buying an impact wrench.(G)
hellosailor is offline
post #24 of 25 Old 06-05-2019
I have a 3GM30 as well, with a 120a alternator.
I use Dayco TopCog belts, long enough not to be forced on, yet can be tensioned sufficiently.
You (or someone) mentioned Kevlar belts. Don't! At least w/o checking the specs. There is a minimum sheave diameter that can be used without damaging the belts. I learned this after ruining two belts in quick succession. They went slack in a matter of hours. The non-stretch Kevlar on the perimeter forces the rubber at the bottom of a small sheave to be compressed more than it can handle.
ggray is offline
post #25 of 25 Old 06-06-2019 Thread Starter
thanks for that info. I have decided to use the OEM belts for now.
Mitsuboshi Belts obelisk Engines 3 06-02-2015 01:37 AM
Balmar Alternator Eating Belts sjacovino Diesel 18 12-09-2013 09:26 AM
Going thru alternator belts??? stepping stone General Discussion (sailing related) 20 11-27-2012 03:59 AM
2gm20F Fan Belts rjc9136quinn Diesel 9 10-08-2009 04:02 PM
Rofan Alternator belts SYCricket Gear & Maintenance 2 12-18-2008 10:00 AM
