2007 Beneteau 343 engine noise - Page 2 - SailNet Community
post #11 of 13 Old 06-20-2019
Dirt Free
boatpoker's Avatar
Re: 2007 Beneteau 343 engine noise
Originally Posted by Minnewaska View Post
Had an engine once that would sound clunky on start up, then settle down. Turned out it was pieces/parts of the broken damper plate that were rattling around, until they got stuck somewhere in the rotation.
And then this happens..... 38' miles out in the Gulfstream.... = rough day on the water.
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is online now
post #12 of 13 Old 06-20-2019 Thread Starter
davidpm's Avatar
Thanks guys.
I forgot about the damper plate.
davidpm is offline
post #13 of 13 Old 06-21-2019
JimsCAL's Avatar
My bet is still on low idle speed with a cold engine.
S/V First Tracks
1985 Cal 33-2
JimsCAL is online now
