Universal m-18 won’t start sometimes - SailNet Community
post #1 of 12 Old 07-13-2019 Thread Starter
Hello,
I have a Catalina 27 with a universal m-18 diesel motor in it. I replaced the glow plug switch about 6 months ago as the previous one was pretty sticky and wouldn’t disengage anymore
Now I have a separate hut possibly related problem: Today I ran the motor for 90 mins while cruising and got to the dock and shut it off for 10 mins. I tried to start it up again and nothing happened. No motor turning over or grumbling - no anything. I waited a minute and tried again and it started right up no problem. This has happened to be a few times now. I’m wondering if my starter switch could need a replacement?
After only sitting for 10 mins after being ran for so long, the glow plugs should not need to be used so I don’t think it’s a glow plug problem but I’m not sure.
Any thoughts?
sailing11 is offline
post #2 of 12 Old 07-13-2019
Re: Universal m-18 won’t start sometimes
Clean battery connections...1st
RegisteredUser is online now
post #3 of 12 Old 07-13-2019
Then check all the stuff at controls area (dashboard) Learn how to jump the solenoid as part of diagnosis (and emergency start) Solenoid should click ,could be temp sensitive as could be brushes of starter
Capt Len is online now
post #4 of 12 Old 07-13-2019
Learning the HARD way...
eherlihy's Avatar
REMOVE THE TRAILER PLUG CONNECTORS IN THE UNIVERSAL ENGINE HARNESS. Replace with terminal strips.
USCG Licensed OUPV Captain, US/Sailing BKB and ASA 101/103/104/105/106/114/118 Instructor - Also ABYC certified in Marine Electrical Systems,
eherlihy is online now
post #5 of 12 Old 07-13-2019 Thread Starter
Ya I sure don’t like the look of that trailer connection. I wouldn’t be surprised if that is the culprit. It might be above my skill level to change it and I’m hesitant to do it in the middle of summer. Here’s what it looks like. Do you know if it is hard to change?
The Following User Says Thank You to sailing11 For This Useful Post:
CLOSECALL (07-14-2019)
post #6 of 12 Old 07-14-2019
eherlihy's Avatar
I have changed them on several boats. Do one wire at a time, and use quality connectors. The blue butt splices pictured are crap, and should also be replaced. Not hard - for me anyway. There are two of them, by the way, one near the engine, and one near the control panel.
Good luck.
post #7 of 12 Old 07-14-2019 Thread Starter
Roger thanks for the input I’ll give it a look. There’s 2 separate trailer wiring harnesses to replace?
post #8 of 12 Old 07-14-2019
eherlihy's Avatar
One harness - two trailer plugs.
post #9 of 12 Old 07-21-2019 Thread Starter
All the wire connections look ok. All are tight when I try to wiggle them. When it doesn’t start, all I get is a “clicking” noise when I pull out the starter switch but that is it. Then it started ok when I tried again 2 mins later. I’m currently on anchor so I’d like to get to the bottom of this . Any ideas of what to do next in term of troubleshooting ?
post #10 of 12 Old 07-22-2019
eherlihy's Avatar
Check battery voltage. If not that, see post 4
