Diesel Fuel Treatment: Multiple Questions - Page 3 - SailNet Community
 3Likes
post #21 of 24 Old 10-01-2019
Re: Diesel Fuel Treatment: Multiple Questions
If it helps, my Yanmar JH series operation manual, under Additional Technical Fuel Requirements, states, "Do not use biocide".
JoeDunn is offline
post #22 of 24 Old 10-01-2019 Thread Starter
If that is one of their CR Diesels, perhaps they have additional filtering requirements and the very close tolerances have some difficulty with the chemicals in a biocide. Maybe. Perhaps.
OTOH.... I have not heard of such a demand..... so, it's a puzzle.
1988 Olson 34, by Ericson Yachts.
Sail # 28400
Betamarine 25 (new 2018)
RCYC, Portland, Oregon
olson34 is online now
post #23 of 24 Old 10-01-2019
pdqaltair's Avatar
It is an interesting statement. Several thoughts:
* Biobor, to my understanding, is used in most jet fuel. That's a rather critical use.
* Not all biocides are the same. Some (not Biobor JF) will crystallize and fall out if not mixed well. It seems odd to paint them all with one brush.
* If you use a biocide AFTER you have an infection, you will get dead bugs and clogging, and some of that will be on the other side of the filter, where it can damamge injectors.
You MUST use a biocide as a preventative, not as a treatment for existing disease.
Writing full-time since 2014
Author--Rigging Modern Anchors
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is online now
post #24 of 24 Old 10-01-2019
Location: The house is in Kingsport, TN. Boats are on Watauga Lake and in New Bern, NC
It is on page 35. https://www.yanmar.com/media/global/...JHM-M00201.pdf
I worry about the butyl cellosolve in the FPPF Marine Diesel Fuel Treatment that I added to my diesel fuel tank before I had an o-ring failure. Dow Chemical says "Do not use Viton, neoprene, nitrile or natural rubber gaskets or seals." http://msdssearch.dow.com/PublishedL...romPage=GetDoc on page 4.
Of course, medicine or poison, it is all in the dose.
Bill
wsmurdoch is online now
