Anodes on Yanmar 2gmf?? - SailNet Community
 4Likes
post #1 of 11 Old 10-08-2019 Thread Starter
Does anyone know if there are anodes on the 2gmf (fresh water cooled)? The manual shows anodes for the 2gm version but unsure if the 2gmf requires anodes to be be inspected/changed.
Thanks!!
apm1310 is offline
post #2 of 11 Old 10-08-2019
Re: Anodes on Yanmar 2gmf??
I'm nearly certain the answer is yes, but my shop manual is on the boat and I am not. I'll bump the thread later in the week if you don't get a definitive answer.
drew1711 is offline
post #3 of 11 Old 10-08-2019
None of the gmf (2gm, 3gm) freshwater cooled engines have anodes, Yanmar says it's because they don't use dissimilar metals in the heat exchanger.
"Just call me TB"
capttb is online now
post #4 of 11 Old 10-08-2019
You may or may not have one in the hx.
Id check that
RegisteredUser is online now
post #5 of 11 Old 10-08-2019
JimsCAL's Avatar
My 3GM30F (and I believe the 2GM also) has a Cu-Ni heat exchanger and has no zinc anode.
RegisteredUser likes this.
S/V First Tracks
1985 Cal 33-2
JimsCAL is offline
post #6 of 11 Old 10-08-2019
Senior Moment Member
SloopJonB's Avatar
I've owned two 3GMF's and one 2GMF and none had anodes.
JimsCAL likes this.
SloopJonB is online now
post #7 of 11 Old 10-09-2019
PhilCarlson's Avatar
Dock
I spent a lot of time looking for anodes in my 2GM20(f)... There aren't any.
capttb likes this.
PhilCarlson is offline
post #8 of 11 Old 10-09-2019
Originally Posted by PhilCarlson View Post
I spend a lot of time looking for anodes in my 2GM20(f)... There aren't any.
Me too, Phil, I recently spent 45 minutes looking for the transmission dipstick on my new pickup, there isn't one.
PhilCarlson likes this.
"Just call me TB"
post #9 of 11 Old 10-09-2019
I thought for a while that the world has passed me by, is now confirmed for sure!
My understanding on Yanmar GMs
On GMF's (fresh water cooled) with heat exchanges. No anodes.
On GM's (raw water cooled) Yes anodes. One each cylinder.
On my 3GMC , raw water cooled / C= saildrive there are total 3 anodes (zincs as I call them) 2 along side of motor, under exhaust manifold, (one is behind secondary fuel filter) and 3rd is mounted on end next to exhaust elbow.
For saildrives, in addition to external lower, there is an anode up on side of SD.
Opposite side from water intake up high near yellow oil fill cap.
Not all are aware this one exists.
Is an adventure to change them!
HUGOSALT is offline
post #10 of 11 Old 10-11-2019
roverhi's Avatar
I asked the largest dealer of Yanmars on the west coast and was told there are none. The heat exchanger internals are cupronickel rather than the copper of most others so don't require an anode.
roverhi is online now
