SailNet Community (https://www.sailnet.com/forums/)
-   Diesel (https://www.sailnet.com/forums/diesel/)
-   -   Installing new engine (https://www.sailnet.com/forums/diesel/331614-installing-new-engine.html)
Minnewaska 10-15-2019 12:50 PM
Re: Installing new engine
Originally Posted by Rockter (Post 2051631042)
...The alternator belt on my boat is well beyond its 10th year, the impeller 25 years, the engine hoses 30+ years......
My grandmother smoked every day and died at the age of 94, from natural causes. That doesn't make smoking a recommended practice.
I implore the OP to do their own research and see what the proper advice is. A 25 year old impeller is as edge case as I've ever heard.
Hose and belts typically last longer than their shelf life. The question is whether you want to determine their durability underway, or follow best practices and avoid being stranded or causing collateral damage.
Waltthesalt 10-15-2019 05:52 PM
Thanks to everyone for all the great advice! I'll post the results when I get the engine in. Gotta' love Sailnet.
Scotty C-M 10-15-2019 08:25 PM
If it works, leave it alone.
If they look or sound distressed, they get replaced, not before.
There is no way on this earth I would change the belts, impeller, or hoses on a motor that had never been used.
Run it first, see how they perform, see how they look, then decide.
Not before.
You might want to re-think this one. Parts wear out, but they also degrade with age. An engine hose at 30 years? Unless you are really careful in checking them, you might be headed for a failure. A failure, by the way, could cost a lot of money, or happen at a time when the boat could be placed in jeopardy. But, if you're really on top of checking them.... An impeller, however, cannot be checked unless you take it out - at which point you might as well just replace it. An impeller that fails can overheat an engine really fast.
I'll illustrate my point with two stories:
A friend at the harbor is a really good sailor. Nice boat too. He came back in after a daysail with his mast broken in two. Turns out that the turnbuckle failed. Older boat, hardware older than the replacement schedule. I saw the turnbuckle. Where it failed, it was rusty along the failure surface. In other words, the failure was a long time coming. Not an engine failure, but a failure that could have killed someone if luck had gone against him.
Second story. Friend's boat, different friend, engine stopped. I towed him in. He cleaned all the filters and went to his boatf the next week, but the engine wouldn't start. Turns out that a bunch of crud had blocked the intake tube inside his diesel tank.
My point is that you don't have to go crazy, but you do need to maintain your boat systems. At least replace that impeller. In my experience, it pays off to do filters, belts, fluids, clean it and look for anthing else that you can do. A stitch in time saves nine.
Just my opinion, and how I run my boat. Your boat, your choice.
chef2sail 10-15-2019 10:46 PM
25 years on an impeller. Not sure I understand the logic of risking a $10 part replacement vs having the fish the vanes out of the heat exchanger.
capta 10-16-2019 08:54 AM
Not before.
You are bragging about not changing your impeller in 25 years?
I wouldn't leave the dock with you on that boat if it was sailing after Noah's arc had sailed and it was my only hope!
Rockter 10-17-2019 11:09 AM
Maybe he should replace this one as well, eh? A Kubota will have something in there similar, won't it?...
Volvo Penta GUMMIKUPPLUNG - Ersatzteilnummer 827615 - Schmidt & Seifert
After all, it might fail one day unexpectedly.
And it's only $360 bucks.
Then there is the gearbox final drive seal, and the crankshaft forward seal, and the crankshaft aft seal, and the valve guide oil seals.
They have all got to be changed too, don't they?
After all, they are 10 years old and might fail, mightn't they?
And when he is digging in there trying to get them out there is no telling what else he might find or break on the way in. I mean the engine is Japanese, and nearly all those fasteners will have been impact-driven at the factory, and man they are hard to shift sometimes, eh?
Imagination knows no bounds (nor expense).
The mind boggles !
Rockter 10-17-2019 11:32 AM
Capta :
I am not bragging about anything and i wouldn't let you on my boat as i could not stand the constant critique (and expense) of trying to keep you happy. After all, nothing must be older than 10 years as it might fail, even the whole boat.
The impeller pumps and pumps strongly.
When it doesn't I will change it... there are two impeller spares on board, and a spare pump, and two starters, and a spare gearbox, and a spare alternator.
As for seaworthyness and the Arc and all that, well my boat took me across the North Atlantic, you know (?) through the usual gales and so on, and it still floats, and i changed the coolant impeller 25 years ago.
How far has yours sailed without stopping for spare parts? Six times round the world no-doubt?
chef2sail 10-17-2019 04:00 PM
Originally Posted by Rockter (Post 2051631478)
Capta :
Rock,
We got your point.
There is nothing wrong with you following your own philosophy.
Just like there is nothing wrong with me following a preventative approach. Many have a PM approach to items which wear out on their boat.
Scotty C-M 10-17-2019 11:23 PM
So I looked up the manufacturer's recommendation for replacing the impeller on my Yanmar 3JHAE. It says every 4 years or 1000 hours. That sounds appropriate.
Rockter 10-18-2019 12:56 AM
Yes, what works for you, certainly, follow it.
But would you change all the hoses, the impeller, and all the seals on an engine that has never been used?
Remember that if anyone claims that the hoses are degraded, then all the seals will be too.
Would you change out all the engine seals - all of them - as some sort of PM campaign on an engine that has never been used?
Have you ever tried removing the crankshaft seals to see how much work that is? And when you put it together again, does anyone claim that they can do a better job than the assembly line?
These engines DETEST being disturbed like that.
Wait until the first oil drips start - where previously there were none - then get back to us with this all-encompassing "PM" approach.
To me, that is beyond comprehension - just, like, out of it, somewhere.
Start it, run it, heat it up, bollard test it, wobble the hoses, get out the magnifying glass, and make your decisions, but to throw usable hoses and impellers and seals in the bin every five years and to dig out all of the engine seals starting with an engine that has never been used????
Really????
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging v3.1.0 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
