Alternator robbing HP, what's the right idle? - Page 5 - SailNet Community
 10Likes
post #41 of 44 Old 02-04-2020
SanderO's Avatar
Re: Alternator robbing HP, what's the right idle?
Originally Posted by Scottrgrewe View Post
Is this correct?
Do I NEED a new pulley?
If so, did I calculate correct size?
Where to buy?
Do the math for your max maintained RPM (motoring???) and the alt should be spinning at it rated max RPM... and then determine the diameter of the pulley you need. I am guessing is may be larger in the 4" range... You don't want the alt spinning too fast as you don't want your engine over it "red line"... The alt RPM is a ratio of the Flywheel crank circumference / alternator pulley circumference
Engine RPM / flywheel circum = alternator RPM / alt circum
You should know the MAX alternator RPM and so you SOLVE for the alternator circumference
so it might be
2,000/14 = 6,000/x
14/3 = +/- 4.5
if max alt speed is 6,500 for engine 2,000 RPM
If Alt RPM is higher alt pulley diameter would be LESS than 4.5"
The alt maker can supply you another pulley or perhaps a local alternator shop like Bronx Ignition... I can get one for you and ship it if you can't find it down there.
pay attention... someone's life depends on it
SanderO is online now
post #42 of 44 Old 02-04-2020
I have got the same engine and flywheel.
If I try to charge at idle, the belt shows signs of dancing and distress.
Keep your revs up at high alternator amperages.
Rockter is offline
post #43 of 44 Old 02-04-2020 Thread Starter
Scottrgrewe's Avatar
What size is your alt pulley? Is mine too small?
Scottrgrewe is offline
post #44 of 44 Old 02-04-2020
SanderO's Avatar
you want an ouside diameter for the pulley to be 4.5" - 4.75"
