Gear and Throttle sticking - SailNet Community
 1Likes
post #1 of 11 Old 04-04-2020 Thread Starter
I have the older morse system for my gear and throttle. Although they're next to each other, they used to operate independently. Las year, they starting sticking so that when you put one forward, the other goes forward. Basically you need two hands to operate it which sucks.
I tried putting some transmission fluid on it to lubricate it but it didn't work. I was told by a mechanic not to use WD-40. Any ideas on another product to use that maybe has better penetrating qualities?
sailing11 is offline
post #2 of 11 Old 04-05-2020
chef2sail's Avatar
Re: Gear and Throttle sticking
Something with Teflon
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
post #3 of 11 Old 04-05-2020
Probably needs to be cleaned up.
Maybe try emory cloth
Smooth
RegisteredUser is online now
post #4 of 11 Old 04-05-2020
Needs to be disassembled, cleaned, and greased. It's rusty inside, also.
olson34 likes this.
WrkrBee is offline
post #5 of 11 Old 04-05-2020
Old rusty parts clean up well, soaking in 50/50 solution of vinegar and water. Be careful, because this does eat away at the metal, so not a great idea for things with precise tolerances. Although, rust swells, which could be causing the binding, so taking it back may be exactly what you need. Maybe some stainless steel wool to clean it up after, good fresh water rinse and dry, then something like a light coat of Super Lube on mating surfaces.
Jeanneau 54DS
Minnewaska is offline
post #6 of 11 Old 04-05-2020
Master Mariner
capta's Avatar
I can't imagine why WD-40 would be prohibited, but I'd try PNB Blaster as a penetrant/lubricant.
I'm not sure grease would be a good idea if there is a friction point to keep the throttle in place, but I don't know that unit at all, so this is only a possibility.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #7 of 11 Old 04-05-2020
I don't know the unit either, but most greases will stay in place unless excess is used. Oils, especially spray lubes, can run into unwanted places.
WrkrBee is offline
post #8 of 11 Old 04-05-2020
Master Mariner
capta's Avatar
I only meant that if something is meant to be held in place by friction, grease will indeed stay in place and reduce that friction to near zero. Sprays would wear off or evaporate fairly quickly.
We grease everything on our windlass except the brake.
capta is online now
post #9 of 11 Old 04-05-2020
Not greasing friction surfaces is a good point. I was thinking the rusted shaft was part of the problem.
Jeanneau 54DS
post #10 of 11 Old 04-05-2020
chef2sail's Avatar
https://www.slosailandcanvas.com/mcl...SAAEgIHkfD_BwE
The Sailkote doesn’t drip off and works well. Doesn’t collect dirt either. I use it once in a while on sail tract even though I have Tides track.
Parkville, Maryland
Our blog-
