Universal M-12 alternator and starter wiring - SailNet Community
post #1 of 6 Old 6 Days Ago Thread Starter
This is a little embarrassing. (Happens to me a lot.) I did a lot of work to my Universal M-12 over the offseason on my new-to-me Pearson 27 (first diesel for me), including pulling out the alternator and starter and getting them rebuilt. I usually do a good job of taking pictures and labeling things, but not so good here, in part because I knew I had the service manual with wiring diagram. Now I'm trying to put everything back together.
My alternator has connections POS, NEG, REG, AC TAP. I know what AC TAP is for and I don't have a tach, and REG is connected to the included regulator. I have the standard wiring harness with the trailer light connectors. I know the dangers (from Mainesail and others), and I've read how to fix it. Part of this project is to get rid of those, but I just want to briefly get back to the stock, working condition. Wiring diagram from service manual is attached. So #4 goes to POS on the alt. Where does #11 (jumper from alt to starter positive) go? In the diagram, it is labeled "Sense" on the alt? Does anything get connected to NEG on the alt? Right now, #1 is connected to the engine block. Should #1 go on NEG on alt?
#LabelAndTakePicsNextTime
w7thmark is offline
post #2 of 6 Old 6 Days Ago
Learning the HARD way...
eherlihy's Avatar
Re: Universal M-12 alternator and starter wiring
I honestly can't remember... but I think that without a tach. you can just let it float.
One of my first upgrades to my M25 was to up from the stock 51A Motorola alternator to a 90A Leece-Nevile.
Get rid of the trailer plugs ASAP. And your Alternator + lead should go directly to your batteries, NOT to the instrument panel.
USCG Licensed OUPV Captain, US/Sailing BKB and ASA 101/103/104/105/106/114/118 Instructor - Also ABYC certified in Marine Electrical Systems,
eherlihy is online now
post #3 of 6 Old 6 Days Ago
alanr77's Avatar
Get rid of the trailer plugs ASAP. And your Alternator + lead should go directly to your batteries, NOT to the instrument panel.[/QUOTE]
This.
Many older systems had the battery return go through an ammeter and required this to function. Modern systems instead have a voltmeter if anything at all. Thereby not requiring anything other than a direct connection to the batteries. Alternators require only an input, output, ground and if it’s externally regulated, wire for that.
SV Salinity
alanr77 is online now
post #4 of 6 Old 6 Days Ago
Super Moderator
Maine Sail's Avatar
We would need the exact LN part # of your alternator, or an image of the back of it, to even begin to help. Universal used numerous different alternators/regulators over the years.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #5 of 6 Old 5 Days Ago
Super Moderator
Maine Sail's Avatar
Also, your alternator should not be running through that ammeter circuit. Boats have burned to the waterline due to this and removing the ammeter circuit and its wiring should be your first priority. Getting "back to factory wiring" should not be a consideration as the factory wiring is dangerous.
______
post #6 of 6 Old 4 Days Ago Thread Starter
OK, I got it all working again "the stock way". The boat is still on the hard and I ran it once. I had less than 10 volts at the starter ignition and the engine wouldn't start. Corrosion on the starter button terminals, small gauge wire through the 2 trailer connectors. (I left the trailer connector disconnected over the winter and I think even more oxidation built up on it.) What a disaster. I consider myself lucky that I made it through season 1 with this boat without it turning into a floating charcoal briquette.
I ran a temporary wire straight to the positive battery cable and it started right up. Now I'm replacing the glow and start buttons, heavier gauge wiring to the starter, replacing trailer connectors with bus bars, and removing the ammeter per Mainesail's instructions elsewhere.
Thanks to all 3 of you for the help. Mainesail, in particular, you're a treasure to this community. I'm slowly making my way through everything you've ever written.
w7thmark is offline
