Bleeding problems on a Yanmar diesel engine - Page 2 - SailNet Community
post #11 of 12 Old 11-19-2009
I did something similar on my Yanmar 3qm30. I used 4 gate valves from the hardware store and an electric pump with 2psi output. I can isolate the engine from the filters and pump fuel thru the filters and back to the tank or use the electric pump if my mechanical fails. sure makes it easy to change the fuel filters.
dmtjoy aboard SV Pegasus
dmtjoy is offline
post #12 of 12 Old 12-02-2009
joshw5144's Avatar
I learned something this summer when I ran out of fuel, that might help incase anyone else has the same issues. My engine is a 3gm, when I was pumping with the manual lift pump nothing was coming out. After 300+ pumps I knew something wasn't right. Well turns out that my lift pump has some give when you first press it down. Maybe 1/2" or so, then it felt like it was at the end of the stroke. Only when I got reallly mad and pushed way harder than I thought was needed did I find the "second" stage of the pump. Couple minutes later fuel was flowing. Very frustrating @ 1:00am.
joshw5144 is offline
Bleeding your Yanmar Engine artbyjody Gear & Maintenance 41 09-23-2016 11:03 PM
Problems Bleeding Fuel Lines in Yanmar 3GM30F Watkinzz Diesel 11 05-19-2015 11:29 AM
Bleeding a Small Ynamar Diesel fuel system Jeff_H Diesel 6 07-15-2009 11:03 PM
Bleeding the diesel ericob Gear & Maintenance 3 06-21-2008 10:16 PM
Oh No! New Owner with another Diesel Bleeding/Fuel Question arf145 Gear & Maintenance 23 09-20-2007 11:19 PM
