Oil pressure light fades on/off - Page 2 - SailNet Community
post #11 of 13 Old 12-31-2009
Learning the HARD way...
eherlihy's Avatar
Maybe you're getting chafed
USCG Licensed OUPV Captain, US/Sailing BKB and ASA 101/103/104/105/106/114/118 Instructor - Also ABYC certified in Marine Electrical Systems,
eherlihy is online now
post #12 of 13 Old 12-31-2009
A shop manual should also tell you how to test the switch itself. Often that's either an on-off connection or a variable resistance (most common) and you can test the sender with a multimeter. Senders do go bad, and if that happens you just throw it away and screw in a new one. A gauge is no panacea, it can malfunction too. And if the sender is bad--the gauge won't work either.
hellosailor is offline
post #13 of 13 Old 01-01-2010
CarelessNavigator's Avatar
The type of OP gauge I was recommending has no sending unit that could fail. A Mechanical gauge has OP sent directly to the gauge itself via a plastic line and fitting where the sending unit thread into. The biggest danger is the line springing a leak. If you have a problem with a mechanical gauge it is way easier to tell and in my opinion more reliable than all other types of OP gauges.
Why not have the best of both worlds and install a T fitting and use the light and the gauge. What ever blows your skirt up.
CarelessNavigator is offline
oil pressure light M-5411 Universal jimd333sail Diesel 3 09-12-2011 09:36 AM
No oil pressure after oil change brob76 Diesel 30 10-16-2010 11:52 PM
lube oil pressure light endevour Gear & Maintenance 2 09-24-2009 04:53 PM
Yanmar Oil Pressure Light/Alarm Out? Please help! gwp Gear & Maintenance 1 05-19-2008 11:32 PM
W60 - No oil pressure after oil change??? pma_foyl Gear & Maintenance 9 12-01-2004 09:45 AM
