Minimum amount of compression to fire a diesel - Page 3 - SailNet Community
post #21 of 22 Old 03-13-2010 Thread Starter
huguley3's Avatar
It sat for a day because of crappy weather yesterday. I put the SOs hair dryer on the injectors and the fuel lines. It started after a few cranks so it was not an instafix but it seemed to help. Not sure if there is an objective way to measure something like how effective a fix is with so many variables.
I dumped a few ounces of marvel mystery oil in the crankcase. It did not blow up or anything spectacular. I will change the oil in a couple of weeks to get that out of there.
I tied an extra spring line on and put the engine in gear so I could get it up to temp. I could not figure out why it would not warm up like it should until I checked the thermostat wire and it was disconnected. Its always something I guess.
30' Islander Bahama
huguley3 is offline
post #22 of 22 Old 08-29-2016
Re: Minimum amount of compression to fire a diesel
I know this is an old post but I have been a diesel mechanic for many years and there is always something that people forget.
That would be battery and starter condition. These directly affect cranking speed. Cranking speed is much more critical on a diesel than a gas engine for reasons mentioned above related to "heat sinking". The stirling engine uses that principle to run. Basically the head, piston, and cylinder wall will sap the heat right out of the air at an incredible rate. If the engine cranks too slow the required heat is gone before the injector fires. Many GM diesel cars and trucks came with 2 batteries from the factory. I actually added a third to help the two last longer and facilitate faster cranking, thus faster starts on my diesel van.
If you are into getting the most out of tired diesels I would highly recommend 3 start batteries or at the very least checking and cleaning all electrical connections and possibly upgrading the starter whichever way you can. I have found some of the newer gear reduction starters (for GM vehicles) seem to be able to crank a bit faster. Just my two cents.
Consaka is offline
Annual maintenance amount randomforumname General Discussion (sailing related) 31 08-27-2012 02:48 PM
so whats the least amount of wind you have sailed a spirit in? Southron Spirit North American Yachts 3 06-19-2012 11:45 AM
A bit of a pickle...financing a small amount for a larger boat? gigamanx Boat Review and Purchase Forum 6 04-04-2012 05:44 PM
Amount of crabs for 20? brmn54 General Discussion (sailing related) 5 06-01-2006 02:11 PM
