How to clean a heat exchanger core? - Page 2 - SailNet Community
post #11 of 11 Old 03-08-2010
Originally Posted by SteveInMD View Post
I think I'll just keep it simple and stick with the green stuff.
I used the Prestone green stuff for years (1985 Perkins 4-108) until recently when a long haul trucker suggested going with the heavy duty stuff(Prestone orange -red) Apparently there is more corrosion protection in it vs the green and I did switch the system out after proper flushing. After I did it I read that the 4-108 has dry cylinder liners whereas the wet liners are where the heavy duty stuff is really needed so my efforts were for not. Not switching back any time soon. I did not go with the extended life stuff.
lancelot9898 is offline
Heat Sheild for Heat Exchanger Philzy3985 General Discussion (sailing related) 2 12-23-2015 08:32 PM
Best way to remove and clean heat exchanger Perkins 4.236 edwmama Gear & Maintenance 10 10-29-2011 03:40 PM
Heat exchanger cleanup and cleanout dargiem Gear & Maintenance 2 01-31-2003 04:52 PM
heat exchanger gunk creek Gear & Maintenance 0 06-06-2001 06:55 PM
heat exchanger gunk creek Gear & Maintenance 0 06-06-2001 06:54 PM
