ignition problems universal - SailNet Community
post #1 of 4 Old 05-22-2010 Thread Starter
Unhappy ignition problems universal
I have a M25 XP Universal. In the off position with the battery on the fuel pump and engine alarm are constantly on. Usually they are only on when in the run position which is correct. When engine starts the alarms go off but when i shut engineand and turn pump and alarm run (correct), then switch to off positin and they stay on. Queston is mechanic says ignition switch is fine, i disagree because it makes no sence. How can switch be good and alarm and pump run when in off position, What else could be making it run in the off position.
Michael
Seaduced8104
seaduced8104 is offline
post #2 of 4 Old 05-22-2010
mitiempo's Avatar
Were any wires changed or was anyone working on the engine recently? I can't think of anything else that could cause this to happen.
Brian
mitiempo is offline
post #3 of 4 Old 05-22-2010 Thread Starter
no one working on boat. is it possible the switch is bad. my thought is that in the off position it is shorted and not supposed to run.
post #4 of 4 Old 05-22-2010
mitiempo's Avatar
If it is shorted and "off" is actually "on" that would do it. Easy enough to test with a multimeter. Check to see if there is a voltage reading from the run terminal with the switch off.
Brian
mitiempo is offline
New ignition switch for Universal 5416 jimgo Gear & Maintenance 24 07-15-2014 03:02 PM
Westerbeke/Universal Diesel Problems stowe18 Gear & Maintenance 18 07-29-2013 08:51 PM
Intermittent starting problems with universal aeronca Diesel 6 09-05-2011 07:59 PM
Universal 25, starter problems Fearlessfrog Diesel 0 08-06-2011 09:30 PM
Universal m3-20 problems. JBIZZ Gear & Maintenance 5 02-03-2011 08:14 PM
