Universal 5432 Front Crank Shaft Seal Leaking - SailNet Community
post #1 of 7 Old 01-03-2011 Thread Starter
Hi,
I have a Universal 5432 in my Mariner 36, that is leaking from the front crank shaft seal. The shat is spining the oil out all over the front of the engine. I can see a drip running down behind the pully. I'm thinking about pulling off the front case but don't know what I'm in for. I have look at the parts mamual but I can't see if the case will unbolt without distrubing the injector pump. Thank for your help. If you e-mail me I can send my office 800 # if you want to discuss this by phone.
Mariner36 is offline
post #2 of 7 Old 01-04-2011
MARC2012's Avatar
On most motors removing the timing cover will not allow you to change the front seal on the crank.I would double ck if that is the source.marc
MARC2012 is offline
post #3 of 7 Old 01-04-2011 Thread Starter
Thanks for the reply. I look at the parts manual and the seal is in the front case. My concern is wehat i'mk getting into when I go to remove this front case. I can live with the leak if this is going to turn into a major job. I can't find a maitance manual that gives me any drawings of what is inside the case. Any ideas would be appreciated.
post #4 of 7 Old 01-04-2011
You will basically have to remove the crankshaft pulley and the ancilliary equipment before removing the timing cover. The nut holding the pulley will be your biggest challenge. Using a impact wrench will help a lot if you can borrow one, then use a torque wrench to tighten agter replacing gaskets and seals.
r.furborough is offline
post #5 of 7 Old 01-04-2011 Thread Starter
Seal leaking
Thank You for your reply. I have several question that I hope you can answer. Rather than typing them out, I type with one finger, if you would prefer you can call me at my office in CA at 800 811-2009. I'm usually in from 10:00 - 6:00. Thanks again, looking forward to talking with you. George Sparr
post #6 of 7 Old 04-20-2011
Probably old hat by now, but there is a spacer/sleeve on the crankshaft behind the pulley, and I believe the seal rides on that spacer. There is also an o-ring behind the spacer which prevents oil from leaking out between the shaft and spacer. If this O-ring were to leak the oil would appear to be coming out from the shaft behind the pulley, or even from the nut side of the pulley. You will want to rule that out first, or just replace the O-ring with the seal to be sure.
It is theoretically possible to pull out the spacer without removing the cover, but you would have to get a grip on it without marring the surface on which the seal rides. The spacer is not all that tight and could probably be removed with just fingers. The pulley is tight and you will need a 2 bolt puller with the right metric bolts. there is a keyway in the pulley but not the spacer.
In fact, with the right hooks, and with the spacer removed, you could probably pull the seal without removing the cover.
If you pull the cover, its the governor springs you have to worry about. if you don't watch it you will stretch them and then have all kinds of problems getting the rpm to be stable. You can access both springs before the cover is lose, but its hard to unhook them. I think one accessible from the side cover plate below the injector pump and the other by removing the stop lever assembly from the top of the cover. Its even harder to hook the springs back up, and I have had better luck connecting at least one spring while the cover is not quite on yet.
The cover has a coolant passage or two around the water pump, so be sure to clean the old gasket off uniformly everywhere and check the surface near the coolant passages. they could be rather narrow from corrosion. a water leak there will not be immediately evident and would result in water in your crank case.
All the parts are Kubota, so you can get them at a tractor place online. 5432 might be the V1501 engine (L345?) but look it up because that is only a vague memory.
Disclaimer: I usually can't remember what I had for breakfast, so all of his may be wrong. In any case, start with the pulley and have a good look before you pull the case.
Also, how is your oil pressure? If the front seal is bad it might be because the front bearing is bad and the shaft is vibrating. Anyway, hope this helps someone BEFORE they re-power.
Unruhly is offline
post #7 of 7 Old 04-21-2011 Thread Starter
Front seal leaking
Thank You for your reply. I found a mechanic who replaced the seal without removing the front case. Yes he did replace the front spacer. Leak is gone!
Solved thermostat problem on Universal 5432 bwindrope Gear & Maintenance 11 02-01-2016 05:39 PM
Universal 5432 head removal discoverer37 Pacific Seacraft 2 04-20-2011 08:32 PM
Pss Shaft Seal Magic1 Gear & Maintenance 16 10-07-2010 02:03 AM
PYI dripless seal leaking drynoc Gear & Maintenance 18 01-19-2010 08:04 AM
Universal 5432 Alternator ol55 Diesel 2 07-01-2009 09:43 AM
