Older Yanmar.. rebuild? replace? or?... - Page 28 - SailNet Community
post #271 of 275 Old 04-05-2011
casey1999's Avatar
Originally Posted by mitiempo View Post
Encapsulation of the visible parts of the keel bolts is the problem. Leave them uncovered, keep them clean and try to keep the bilge dry, at least sometimes.
Roger that, I am going to try to set up a bilge pump that will take care of the shaft seal water before it even hits the bilge. This should take care of a lot of the water.
casey1999 is offline
post #272 of 275 Old 04-05-2011
mitiempo's Avatar
Casey
What boat do you have? You may have said but I can't recall.
Brian
mitiempo is offline
post #273 of 275 Old 04-05-2011
casey1999's Avatar
Casey
S&S 34 Built in Australia (1978)
post #274 of 275 Old 04-05-2011
mitiempo's Avatar
One possible solution is to glass in a bit of a dam to keep the daily drips from the stuffing box in the aft part of the bilge, but low enough that a flood would fill the main bilge. Then the main bilge over the keel bolts could be kept dry with a sponge after it is pumped out. A small low profile pump could be used in the aft section, like the Whale Supersub. A stuffing box that only drips when the engine is running helps as well.
Nice boat - I see it is back in production. Introducing THE NEW S&S 34
No desire to sail around nonstop? It seems to be a popular choice for that.
Brian
mitiempo is offline
post #275 of 275 Old 04-06-2011
casey1999's Avatar
Thanks for the ideas. I may try a non stop, but I have a 4 and 6 year old now and they need to get a bit older, the wife would not allow me to be gone for the 11 months or so, but that also gives me some time to prepare the boat. Whenever I take the boat out, and the kids are acting up, I tell my wife "I might not be back".
Gibsea 43' Rudder Rebuild/Replace Help jkemp Gear & Maintenance 4 11-02-2012 05:45 AM
Rebuild vs replace diesel engine Ilenart Gear & Maintenance 40 02-21-2010 10:23 PM
Replace vs Rebuild? chtaylor Atomic 4 12 01-22-2009 10:08 PM
Rebuild or Replace wcshedd Gear & Maintenance 2 05-21-2003 09:52 AM
REBUILD or REPLACE bombero Gear & Maintenance 0 11-22-2000 05:55 AM
