Yanmar 2QM15 - High pressure fuel pump not pumping - SailNet Community
post #1 of 7 Old 06-29-2012 Thread Starter
aeaston's Avatar
Hello,
Wondering if anyone might have a thought on this. I've got a Yanmar 2QM15 from the early 80's. Its sat for about 2 decades unused, and the previous owner began a rebuild of it, before I got the boat.
I've got the engine reassembled, and it turns over great, great compression.
My lifter pump is working, and I've bled the engine as far as the high pressure pump. Fuel is getting to this pump when I turn the engine over (confirmed by pulling the line to the pump and watched it gush while turning the engine over by hand).
However nothing, not a drip, comes out the high pressure side. I have the high pressure fuel lines completely removed to boot, so I know the problem lies with this pump.
A coast guard mechanic friend donated his time and helped take apart and rebuild the pump, which had been seized. (Plungers were gummed up with old diesel; fuel control rack wouldn't even move.)
We reassembled and everything moves freely now, but I still don't get a drop of fuel out of the thing.
I've adjusted the injection limiter according to the manual, and even if we'd completely buggered up the control sleeves, I'd still expect to see SOMETHING out of the high pressure side of the pump.
Anyone familiar with these types of pumps? (Bosch integral type injection pump) Please someone just tell me I'm being stupid somehow, and there's a simple obvious solution!
Thanks,
-Adrian
aeaston is offline
post #2 of 7 Old 06-29-2012
fryewe's Avatar
Re: Yanmar 2QM15 - High pressure fuel pump not pumping
Do you have the injection pump cover shimmed properly? Proper shim height is critical.
Are you sure you have the governor set up properly to engage the rack?
Doing a bench rebuild of this pump seems like a hit or miss proposition especially after setting for so long.
New pump from Yanmar dealer was 632 last year when I had a problem with a sticking rack due to corrosion. A lot of money but I was tired of the unreliability. It worked a charm.
fryewe is offline
post #3 of 7 Old 06-30-2012
Perhaps a shop could re-build and re-calibrate it for you for less than $632?
Paul T
dabnis is offline
post #4 of 7 Old 07-02-2012 Thread Starter
aeaston's Avatar
Thanks for the replies. I think it is properly shimmed. We re-used the shim materials so that shouldn't have changed at all. I checked and rechecked what I'd done with the governor, referencing the manual. I'm reasonably certain that I've set it up properly, and it is engaging the rack.
$632 is not as bad as I'd feared for a new pump, however I think taking it to a shop would be a good subsequent step. If I can avoid the hundreds of dollars in expense, then I will.
I'll let you know what the end result is! Thanks,
-Adrian
aeaston is offline
post #5 of 7 Old 07-02-2012
JimsCAL's Avatar
Since you are getting plenty of fuel to the injection pump and nothing out with the lines to the injectors completely removed, there's definitely something wrong with injection pump. Taking it to have it rebuilt and calibrated makes sense.
JimsCAL is online now
post #6 of 7 Old 07-06-2012
cptjak's Avatar
Disconnect the kill cable from the pump lever and make sure it is pushed
all the way to the run position.
cptjak is offline
post #7 of 7 Old 01-15-2013 Thread Starter
aeaston's Avatar
Figured I may as well update this. I had one of the yard guys come check out the engine to try to start it. He took all of about 15 minutes to start the engine, saying he was "Just finishing a job someone else started". So I suspect I just didn't turn the engine over enough to bleed out the high pressure fuel pump. Nothing else was changed or repaired while he was there. Surprisingly the bench rebuild of the pump went flawlessly.
Thanks for the input!
aeaston is offline
Yanmar 2qm15 fuel problem pfirth Diesel 10 04-09-2011 01:20 AM
yanmar 2qm15 injector pump pfirth Diesel 19 01-21-2011 12:58 AM
what does an electric fuel pump on a 2QM15 Do? 30Irwin Diesel 4 10-01-2009 12:36 AM
Yanmar 2QM15 fuel consumption? 30Irwin Diesel 9 09-04-2009 11:17 PM
Yanmar 2QM15 raw water pump problem menado Gear & Maintenance 3 07-23-2008 02:20 PM
