Full throttle needed to start Yanmar 2GM20F - Page 2 - SailNet Community
post #11 of 25 Old 12-18-2012 Thread Starter
Re: Full throttle needed to start Yanmar 2GM20F
Originally Posted by L124C View Post
I have the same motor as the OP. I always do a cold start at 3/4 throttle, throttling back to idle immediately after start, as directed in the manual. It's over 20 years old, does not have glow plugs, and has never had a starting problem (in the moderate SF Bay Area climate). Kicks on the first crank every time! Once warm, it starts immediately from idle position.
Sounds like a good Yanmar mechanic is in order for the OP. If he is in the Bay Area, List Marine will sort it out in short order. I'll bet they will also tell him to cruise at 3000 RPM when it is running properly. Makes for a happy 2GM20!
Opposite end of the country. I am in NY Long Island Peconic Bays area, pretty much the same climate. My engine at this point stalls after start if I pill back to idle immediately, I have to keep it in the 2000 to 2500 revs until it smoothes out. And, when warm when its running it sounds like there is a man with a hammer in the engine (mechanics called this fuel knock).
73Morgan is offline
post #12 of 25 Old 12-18-2012 Thread Starter
I think OB and Minne are on the right track.. while 350 compression may be on the low side I don't think it's low enough to make starting problematic with good fuel delivery. And that means timing and proper atomization.
If you're cranking for excessive time periods try to remember to leave your RW intake closed until the engine catches. Flooding the exhaust system with RWC is never a good thing.
Having to use wide open throttle during starting seems to be SOP for some of these older Yanmars..
Ok, I am listening, does this apply to fresh water culled engines?
73Morgan is offline
post #13 of 25 Old 12-18-2012 Thread Starter
I looked into compression, and I see that the manual says the Compression Ratio should be at 23, multiplied by atmospheric pressure 14.7, this equals 338 PSI. Surprisingly 350 is above that. The Mechanic did say he took the compression with a warm engine. He also said that the rings might be stuck/frozen, this might make a difference with a cold start. It looks like he might be on the right track.
73Morgan is offline
post #14 of 25 Old 12-18-2012
Originally Posted by 73Morgan View Post
Ok, I am listening, does this apply to fresh water cooled engines?
Yes.. in either case the RW is pumped through the engine (RWC) or a heat exchanger(FWC) and then is injected into the exhaust system to keep the noise level down and to cool the exhaust run out to the transom.
The water is driven out of the exhaust system by the running engine's exhuast gases. If the engine never catches, the rotating RWpump will fill the muffler, eventually possibly backing up into the exhaust manifold where it will find an open exhaust valve and run back into that cylinder. This can cause 'hydrolocking', where the engine won't turn because it can't compress the liquid pocket in the cylinder.
I'm still leaning toward a faulty injector, certainly it's the top candidate for the 'hammer' sound while running.
Faster is offline
post #15 of 25 Old 12-20-2012
aa3jy's Avatar
Cold start procedures for a 3GM30F(an indirect injection diesel) is similar..full throttle as described in the workshop manual which retards timing. Decrease throttle after diesel starts.
DO NOT use any starting type of sprays/fluids as this procedure may result in bent con rods. I personally know what bent rods look like...
aa3jy is offline
post #16 of 25 Old 12-20-2012 Thread Starter
You just gave an excellent reason why I need to fix the starting issue. Water in the head at the valves and hydrolocking can result in some costly damage, aside from getting stuck somewhere and losing a good part of the season. Thanks, for the input.
I agree about the injectors. The way I understand it the injectors are the only thing that could be allowing too much fuel to get in the engine and cause fuel knock. If the Injection pup was failing that would result in not enough fuel. Are my assumptions right?
73Morgan is offline
post #17 of 25 Old 12-20-2012
That's been my experience.
On our last rebuild I ordered a full set of 'reconditioned' injectors. During the break-in period we got some fuel knock that scared the H out of me because it sounded like metal-to-metal contact.. gladly discovered eventually that one of the 'new' injectors was breaking over at under 500 psi = wet fuel = serious knock. Replaced injector and off to the races.
Faster is offline
post #18 of 25 Old 12-20-2012 Thread Starter
That is exactly what my knock sounds like right now.
You and a number of other people are saying the same thing about rebuilt injectors. Surprising that anyone even bothers with them.
73Morgan is offline
post #19 of 25 Old 12-20-2012 Thread Starter
If your engine was built after 1997 that might explain the difference. My manual covers the 1, 2 & 3GM models.
Normal start positing is at medium speed.
The exception is starting in cold weather the throttle should be in high speed with the decompression handle in the decompression position, start cranking and push the lever to the compression position, after it starts pull back to medium speed. There seems to be a conflict because there is a "caution" which states to pull back to idle immediately when the engine is started at high speed. We all know you should not rev a cold engine any more than necessary . The injection timing being delayed at high speed is also there.
I would actually be happy if the engine started right away on a 80 degree day, and came right back to idle without stalling.
73Morgan is offline
post #20 of 25 Old 12-20-2012 Thread Starter
Ran some tests, cranking and playing with the decompression lever with a cold engine does not feel like it changes anything, it only feels like the compression builds up after the engine warms up. This just might be explaining the hard start problem.
73Morgan is offline
Yanmar 2gm20f RPM RobGallagher Diesel 2 06-30-2012 04:24 PM
Yanmar 2GM20F Suave Gear & Maintenance 2 05-16-2011 11:33 AM
Yanmar 2GM20F Work... krozet Diesel 15 04-29-2010 12:41 AM
Yanmar 2GM20F Petar Gear & Maintenance 13 10-02-2009 07:49 PM
Oh... the noise, running full throttle deniseO30 Diesel 2 06-29-2009 12:19 PM
