Thrust bearing for electric drive - SailNet Community
 1Likes
  • 1 Post By Faster
post #1 of 6 Old 01-12-2018 Thread Starter
Repowering a Pearson Triton with electric.
Have sources for motor and controller.
One thing I see very little mention of on the internet is regarding protecting the motor from the large axial thrust forces imparted by the prop.
I see more than one E Propulsion vendor selling reduction gear systems that solve this problem but:
1- they are over $600
2- best I can tell, I may be able to get by w/o reduction gearing.
Any comments on the topics of the need for reduction gearing, and good choices for a simple thrust gear for a 8,000 lb boat?
JMcgill is offline
post #2 of 6 Old 01-12-2018
Re: Thrust bearing for electric drive
Can't help you here, but I edited your thread title to perhaps garner some more specific responses... mbianka??
JMcgill likes this.
Faster is offline
post #3 of 6 Old 01-12-2018
overbored's Avatar
a couple of reasons for a gear drive is that the motor needs to run at a higher RPM then the prop to produce HP and they do not cool well at low RPM
"GOLD RUSH" PRINDLE 16
overbored is online now
post #4 of 6 Old 01-12-2018 Thread Starter
Thanks
JMcgill is offline
post #5 of 6 Old 01-13-2018
Sorry can't help with this question. My Thoosa 9000 system was turnkey including the reduction pully and motor mount with built in thrust bearing. Never had to deal with thrust bearing calculations or supply.
Mike
Currently: Enjoying Summer's sailing season
mbianka is online now
post #6 of 6 Old 01-14-2018
Cruiser
wrwakefield's Avatar
Aquadrive makes thrust bearing systems for boats.
They use CV joints between the power source [i.e., engine/motor] and separately installed thrust plate.
This eliminates prop shaft/drive system alignment headaches, all with no axial load on the drive system.
Cheers! Bill
wrwakefield is offline
Drive shaft bearing weephee Columbia & Coronado 6 02-07-2010 08:17 PM
Drive shaft bearing weephee General Discussion (sailing related) 3 09-10-2009 10:30 AM
Electric drive huguley3 Gear & Maintenance 25 09-04-2009 12:56 PM
Yamaha 9.9 High thrust vs Honda Power thrust docrn General Discussion (sailing related) 1 07-27-2009 12:57 PM
thrust bearing? killarney_sailor Gear & Maintenance 4 08-08-2007 08:58 AM
HTML code is Off
