Stereo install question - SailNet Community
post #1 of 10 Old 03-01-2018 Thread Starter
Deciding it was time to swap out the old Jenson am/fm, cassette stereo with something from this century, I bought a function loaded Sony from West Marine.
The Jenson was powered by 3 wires (red, black and yellow) but the Sony has an additional orange-white striped wire. Since the orange-white wire is positive, Iím thinking I could simply marry the unitís positive red and the positive orange-white wires to the boats positive red wire instead of running a new wire from the circuit breakers back to the stereo. Would I be correct in this approach or is this ill-advised?
Also, the Sony has a bayonet style 10 amp fuse in the back of the unit but the Jenson fuses were the wires leading into it. The red has a 3 amp fuse and the yellow has a 1 amp fuse, both glass cylinder types. These fuses now seem unnecessary since the new unit is already fused at higher amps. I am all for safety but keeping the fuses on the wires seems like having suspenders and a belt for pants with a draw string. Should I keep the fuses or would it be ok to remove them?
BTW, when I asked the Sony help chat line about this they said to ask someone else. Not so great customer care and product support.
sailingtime is offline
post #2 of 10 Old 03-01-2018
Tanski's Avatar
Re: Stereo install question
Believe the orange is illumination, from the dash light dimmer if I remember from my truck install.
The stereo should have come with some kind of schematic, never seen one that didn't. I really don't knw if there is a standard for wire colour with automitive stuff.
That is a horse head in the box. Not an alien!
Tanski is offline
post #3 of 10 Old 03-01-2018
overbored's Avatar
The fuses at the power source are to protect the wires not the unit. The fuse on the unit is to protect the unit itself and will not protect the wires. if the wire shorts out and there is no fuse at the power source you could have a fire. If the new unit requires more power you need to make sure the wires are big enough and fused for the size of wire used.
"GOLD RUSH" PRINDLE 16
overbored is online now
post #4 of 10 Old 03-01-2018
You really should have some instructions or tabs affixed to the wires but I think that one of those wires( yellow or orange) should go straight to the battery to keep the clock working when the power is turned off...fused of course.
paulinnanaimo is online now
post #5 of 10 Old 03-02-2018
Sorry to ask such an obvious question, but what does the manual say the orange/where wire is for?
Fuses are to protect wires. The fuses can be removed , providing that the 10A fuse is a lower rating than the wires.
MarkSF is offline
post #6 of 10 Old 03-02-2018
SanderO's Avatar
there is a 12v+ wire which powers the illumination of the display and the clock. GT and a 12v+ wire for the unit itself.
You should wire the clock/illumination wire to a ALWAYS ON buss which is wire directly to the house battery. This is a very small load... however it can and will drain your battery if you don't recharge it with alternator or alternative charging sources.
You should wire you stereo unit to a switch w/ breaker to the main distribution panel which is wired to the main house battery switch.
In line fuses are fine... You might change all your boat's inline fuses to the blade type... easy to identify by their color.
pay attention... someone's life depends on it
SanderO is online now
post #7 of 10 Old 03-02-2018
lillia28's Avatar
Location: Central New Jersey, sailing on the Navesink River and Sandy Hook Bay mostly.
Some of those wires should be switched, some not, One may be for the clock and memory, which should be unswitched, unit power, lighting and antenna should be switched. Usually the antenna wire is power out, which is to say when the radio switch is turned on the wire sends power to the antenna. you may not want to hook that one to a hot lead.
I have been able to find wiring diagrams for older radios on line, I would do a careful internet search. Or, connect each wire separately and see what lights up.
lillia28 is offline
post #8 of 10 Old 03-02-2018
lillia28's Avatar
https://esupport.sony.com/US/p/selec...l?PRODTYPE=117
Try this!
lillia28 is offline
post #9 of 10 Old 03-02-2018
Super Moderator
Maine Sail's Avatar
The Jenson was powered by 3 wires (red, black and yellow) but the Sony has an additional orange-white striped wire. Since the orange-white wire is positive, I’m thinking I could simply marry the unit’s positive red and the positive orange-white wires to the boats positive red wire instead of running a new wire from the circuit breakers back to the stereo. Would I be correct in this approach or is this ill-advised?
Yellow = Stereo B+ or your high-current power wire & and memory
Red = Switched ignition feed usually to the breaker labeled "stereo"
Black = negative
Orange/White Stripe = Dash dimmer so the stereo can dim with the dash lights
A lot of folks think the red wire is what "powers" the unit and this is not correct. The yellow wire is where the head unit power is fed from. Red is just the ignition or switch trigger to activate the unit. The yellow wire fuse should be larger than the red wire fuse.
It would help to know what head unit you have...
______
-Maine Sail / CS-36T
Maine Sail is offline
post #10 of 10 Old 03-03-2018
In older stereos, a couple of decades ago, it was common for the switched feed to be high current, and the permanent one to be low. Modern ones have the reverse. That means installing a new stereo with old wiring will result in drawing too much current down a wire and/or fuse that wasn't meant to supply 10A.
Just had the same problem installing a new stereo in my 86 XJS. The 1A inline fuse in the continuous feed is hard to find, tucked away under the console. Fortunately the wire itself is heavy enough to take 10A.
MarkSF is offline
Stereo install boatboy132 General Discussion (sailing related) 7 12-04-2014 01:03 PM
Table upgrade and stereo install mondofromredondo Pacific Seacraft 2 06-28-2014 05:53 PM
Hydraulic Autopilot Install Question funjohnson Gear & Maintenance 6 11-06-2011 06:53 PM
Stereo question SailChick20 Gear & Maintenance 10 03-05-2009 09:01 PM
Furler install question shadypark Gear & Maintenance 5 11-13-2008 06:02 PM
HTML code is Off
