Electric Conversion log for Kahleesea - Page 27 - SailNet Community
 112Likes
post #261 of 283 Old 07-09-2019 Thread Starter
Re: Electric Conversion log for Kahleesea
Originally Posted by texlan View Post
My boat at the lake is running off of non-isolated dc converters from the 24v propulsion bank. The E29 I am refitting, I plan on running house loads off of isolated "stackable" dc converters, but also putting a couple ~55ish ah floated lead acids (located close to the loads) in to run electric primary winches and the windlass. I don't want to put inductive surging loads like that on converters, and certainly not on the same bus feeding radios/electronics.
You should totally hook us up with more pictures of your install and maybe a video of it running. What BMS did you go with again?
Thanks,
Sean
WK7R
The unit I've been looking at is the Orion 48-12 by Victron.
https://www.thepowerstore.com/orion-...converter.html
I don't have anything that generates any sort of heavy electric draw. My biggest draw is the cold machine, with draws a whopping 6A when running. All my electronics combined draws all of 1A. Even once I get the autopilot running, I doubt my max draw will crack 10A.
Good idea putting a lead acid near your winches and windlass. You might even be able to find a lithium battery that would be even smaller and lighter.
I normally sail solo these days, but next time I take someone else out I'll get some images of the system running. For some reason, people frown upon leaving your boat running with no one at the helm.
The BMS I use is the dilitihium BMS. It fits perfectly with my batteries and is easily expandable.
Captain Canuck is offline
post #262 of 283 Old 07-09-2019 Thread Starter
Originally Posted by mbianka View Post
I have an detent position on my EP control for Regen. Though I usually adjust the control for about a 10 amp draw to turn the prop slightly and eliminate prop drag. It also automatically starts to regen as the wind picks up.
I kept my 12 volt house bank separate from my EP battery bank. Don't like having all the eggs in one basket. Though I do have a 48 volt to 12 volt converter available as a backup.
I like the detent idea. Not sure how I'll implement it, but it's definitely worth looking at.
I think my propulsion bank is wired differently than yours is. I'm running 4 parallel batteries, so if I lose on I only lose that much capacity. This is why I like the stackable converters, too - if I'm running two and one fails, as long as my draw isn't more than one can handle there's no problem. As I often say in my day job, "There's no such thing as too much redundancy."
mbianka likes this.
post #263 of 283 Old 07-09-2019 Thread Starter
Update 7/9/2019
I managed to find some wind yesterday and retest regen, to a point.
The system starts regenerating, barely, at 3.5kts. These are estimations, because regen varies wildly according to my ammeter, with wider swings the faster I go. These numbers represent the average.
3.5kts <.5A
4kts ~1A
5kts ~3A
5.5kts ~4A
6kts ~5Aish - this was very hard to tell, since I couldn't maintain 6kts for any amount of time.
Assuming I can maintain 5kts, that gives me a kwh every 6.5 hours from regen. This isn't enough to make a meaningful dent in the propulsion bank, but it is enough to run all the electronics, once I've moved to a DC/DC converter. Expecting to move at 6kts on the regular on the Chesapeake is unrealistic. In the last 5 years of sailing I doubt I've hit 6 kts steady no more than a few times. One time I hit 7 kts steady, but I was going like a bat out of hell on a broad reach in heavy swells trying to get back into my harbor before a storm hit. I made it. Just.
If I want meaningful amperage to recharge the propulsion bank while sailing, solar is looking like the way to go.
mbianka likes this.
post #264 of 283 Old 07-09-2019
Minnesail's Avatar
I have a 24v battery bank to run my electric motor, and I use the Victron 24-12 converter to power my house load. It works quite well. It puts out a consistent 12.5v regardless of what voltage the main bank is at.
My highest load is a 12v electric drill. If itís really bearing down it will drop the house voltage, so I agree with Texlanís idea to have a separate power supply for hungry electric motors. But it keeps up with the rest of my loads no problem. Small boat, though, so small loads. Max would be a small fan, stereo, chartplotter, lights, and maybe recharging a phone.
My motor (Minn Kota trolling motor) is 50 amps and 24 volts, and I canít quite make 4 knots with that. Considering my boat is a quarter the weight of yours Iím clearly not running as efficiently. I wonder if a different prop would make a difference.
Catalina 22
on a starboard tack
Minnesail is offline
post #265 of 283 Old 07-09-2019 Thread Starter
I'm glad to hear the Victron works well. That cements my thoughts on buying one.
The Minn Kota trolling motor is probably using a prop that's most efficient at 50-60% power. If you're running at at 100% to hit 4kts, you're definitely not getting maximum efficiency. I'm not familiar with the Minn Kota line, but they might have a prop from a bigger motor that would turn more efficiently at full power. At least you're using a pod motor with a direct-drive shaft, which is as efficient as it gets.
Minnesail likes this.
post #266 of 283 Old 07-15-2019 Thread Starter
Update 7/15/2019
The *&(#$& ammeter broke. I'm now searching for a new one. When I turned the power on for the boat I almost had a heart attack looking at the display. Then I realized that the level of power output it's displaying is literally impossible for the battery bank. 297kW of current out of a 9kWh battery? That's capacitor-level discharge. Even when I put the boat into forward and stared the prop spinning the display didn't change. Obviously the sensor is fried. I checked he voltage manually and it came back at 50.4V, which is precisely where it should be.
I really expected the ammeter to last a little longer than two months, even though it wasn't built for marine use. I was hoping to get a season out of it and replace it when I'm back on the hard with something a little more permanent.
I installed a 48-12V converter and removed all but one of my house bank batteries (never hurts to have a backup). It easily runs everything on the boat. I left my fridge on for days to test it, and the drinks were nice and frosty each time I checked on it, even though it cracked 100F one day.
If anyone has a line on a waterproof DC 48V ammeter display that shows amps, volts, and kwh, I would very much like to hear from you. Nothing on Amazon seems to be waterproof.
post #267 of 283 Old 07-17-2019
Update 7/15/2019
Not sure if it's waterproof or show kwh. But I've been using an TBS Expert Pro Hv without problems for years for my Thosa 9000 EP system. https://tbs-electronics.com/product/...nitor-12v-24v/
Mike
Currently: Heading to warm waters over the winter on a variety of boats.
mbianka is online now
post #268 of 283 Old 07-17-2019
davidpm's Avatar
How about waterproofing whatever you can find.
Corrosion X HD, Turbo-coat, and NeverWet
davidpm is offline
post #269 of 283 Old 07-19-2019 Thread Starter
I really liked the unit I found. I'd like something similar that gives me the same but in a more waterproof package.
I prefer seeing voltage rather than a battery gauge. That way I can tell if something cuts out before or after it should.
post #270 of 283 Old 07-19-2019 Thread Starter
As it turns out, it was the sensor package that was inside the boat, not the display, that went belly up. The sensor portion is sealed, so I can only guess that it was badly manufactured. The control board is still OK, but for some reason the actual sensors went crazy. Maybe I can get a replacement board and just swap it out for cheap.
Winners of Harbor Destin Boat Parade announced - Destin Log and Walton Log NewsReader News Feeds 0 12-06-2011 01:20 AM
Electric Conversion andrewoliv Gear & Maintenance 30 11-09-2011 11:06 AM
Jabsco Electric Conversion LakePirate Gear & Maintenance 13 03-01-2011 03:18 PM
Head - electric conversion or new electric head snw Gear & Maintenance 5 04-29-2007 07:07 AM
The Log Investigates - Abandoned Boats Plague Mission Bay in Wake - The Log Newspaper NewsReader News Feeds 0 03-08-2007 03:15 PM
HTML code is Off
