trailer sailer electrical refit: safety first advice - SailNet Community
 1Likes
  • 1 Post By Classic30
post #1 of 8 Old 04-20-2015 Thread Starter
r20
I'm starting from nothing but some old 1975 house wire in my 20 Ranger sailboat. I may reuse the vhf antenna, and the running lights. Otherwise, nothing is salvageable. I lack vhf, lights, bilge pump, and all instruments.
I mostly do 2-3 day cruises around Puget Sound and San Juans. My math tells me I'm looking at ~12 Amp hours of use on busy day. Here's my rough plan, and I'd love any feedback or corrections:
Starting with a new 28AH powersonic, may be too small, considering 2x of them.
BlueSea terminal fuses: http://www.amazon.com/gp/product/B00SE6Z2WI/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
3 circuits from battery:
1) 10A fused automatic bilge pump. (overkill, but she may be seasonally in a slip)
2) 20A fused on/off 12v switch feeding a 4 gang panel
3) 5A fused PMW solar controller
Power switch: http://www.amazon.com/gp/product/B000MTB7XS/ref=ox_sc_act_title_3?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
Panel: http://www.amazon.com/SeaSense-Switch-Panel-Breaker-Rubber/dp/B0009PYBKG/ref=sr_1_1?s=sporting-goods&ie=UTF8&qid=1429571274&sr=1-1&keywords=seasense+breaker+panel
My complete system will include:
Masthead led anchor light (.2A)
deck level led nav lights (.3A)
DSC VHF + GPS mouse (1.2A receive, 5A broadcast)
3 LED cabin lights (.5A)
compass (.1A)
fathometer (.1A)
12V cig (???A)
dual usb charging slots (3A @5v)
auto bilge pump (5A)
Charging is via 40 watts of solar and (5A fused) Morningstar SG4 PWM controller.
What is the best way to protect that 12v cig socket? Put it on a dedicated gang switch on the panel? Otherwise gets lumped in the Accessories gang which shares a breaker with instruments, vhf, etc. I suppose I could connect directly to the 12V switch and fuse independently, maybe that's best?
One debate I'm having is over the auto bilge configuration, or simply using one of the panel gangs for the pump. The boat spends non-sailing days trailered and covered, but maybe not forever.
Where am I headed for trouble? Where can I do better?
Thanks in advance for all I've learned from your past threads!
r20 is offline
post #2 of 8 Old 04-20-2015
Once known as Hartley18
Classic30's Avatar
Dock
Re: trailer sailer electrical refit: safety first advice
Hi r20, welcome to Sailnet.
It looks like you have an interesting project on your hands. My only suggestions would be:
1. Wire the auto bilge pump directly off the battery via one of these:
2. Wiring the cig socket off it's own breaker - even if it means going to a 5-gang.
Have fun!
travlineasy likes this.
Classic30 is offline
post #3 of 8 Old 04-21-2015
travlin-easy's Avatar
There are rubber covers for the 12-V cigarette lighter sockets, some of which, such as those purchased at WM, come with the covers.
As for the batteries, they seem kinda light. I would go with a full size, deep cycle, marine battery. Would also go with a bit larger solar panel if you have the room. That 40-watt solar panel will not be putting out 40 watts for more than a couple hours during mid day, far less early and late in the day.
Those connections are fine in a freshwater lake, but in Puget Sound, the sail air will eat them alive unless you cover the connections with heat shrink tubing and silicone seal. That includes any screw connections as well - a dab of silicone sealant does wonders in maintaining those connections. Left unprotected, you may get a couple years out of them at best.
Good Luck,
Gary
travlin-easy is offline
post #4 of 8 Old 04-21-2015 Thread Starter
r20
What is the right stuff to use for that? I've seen wd 40 anti-corrosion at the local hardware store. Is silicone better for electrical connections? silicone what?
I do have adhesive lined heat shrink tubing coming. My boat is too small to have hatches, so the panel is just on the bulkhead. It's open behind. I was considering using a tupperware type container, such that the lid is mounted to the back of the bulkhead, but I can remove the body anytime I need to swap fuses or whatever.
Or perhaps a small project box? What do people use if the panel isn't contained in a well sealed space? I figure 2 bus bars and the panel is most of what needs protecting.
thanks!
r20 is offline
post #5 of 8 Old 04-21-2015
In the past I've used RTV Silicone cement for coating the connections and nothing seemed to penetrate the sealant. I'm not familiar with the WD-40 product.
If you intend to mound that electrical panel outside, then it MUST be covered with something to protect it from spray and the weather. Any clear cover will work, but be sure it is vented at the bottom to prevent moisture forming from condensation. If the boat has a Bimini top, you may wish to consider installing an electronics box similar to those used with powerboats on Tee Tops. Or, you could install a recessed, covered box into the gunwale of the boat, which is fairly easy to to as well. I've seen them installed on cabin face bulkheads as well. The box can be spacious enough to hold your electrical panel and VHF Radio, yet still be almost flush with the bulkhead. They look something like a glove box in a car, but have a clear door.
Good luck,
Gary
post #6 of 8 Old 04-22-2015
Suggest separate switches for anchor light, nav lights, and steaming light, for convenience. Then separate ones for instruments, vhf, 12v outlet, and cabin lights. You dont want a fault in one circuit, tripping the others. Then always have a spare, so we are up to 8.
MarkSF is offline
post #7 of 8 Old 04-22-2015
To prevent terminal corrosion, I prefer dielectric grease. Naturally, it's greasy, but it works and is easily applied/removed.
Jeanneau 54DS
Minnewaska is offline
post #8 of 8 Old 04-22-2015
Living the dream
ReefMagnet's Avatar
My $0.02 to add.
Mount corrosion prone stuff in an appropriately sized industrial weatherproof container behind the companionway where it will be out of the weather. Glands are used to prevent water ingress to the inside of the enclosure and you can even buy them with a door to allow fast access.
Terminate all connections with double wall heat shrink and slap silicon or lanolin grease on stuff (including light sockets) to provide corrosion protection.
Don't use a 20 amp switch for the main, use a 100 amp or so waterproof switch as used in many trailerable boats. Not for current capacity, but for reliability.
Wire your bilge pump on separate auto and manual circuits for redundancy and consider a manual pump accessible from the cockpit.
Your boat, being a trailer sailer, I'd buy the cheapest lead acid battery I could find at around 40 to 60 amp hours. It will give a good compromise on performance and price with fair warning when it is failing.
ReefMagnet is online now
I need trailer sailer advice IwanaBrich Boat Review and Purchase Forum 5 04-28-2009 07:39 PM
Looking for a trailer sailer kruucks Boat Review and Purchase Forum 10 09-30-2008 09:39 AM
A new trailer sailer Giulietta General Discussion (sailing related) 33 05-27-2008 04:46 PM
looking for a trailer sailer hillbillybear Boat Review and Purchase Forum 28 03-27-2008 12:57 PM
Electrical refit Tequiza Terri Gear & Maintenance 3 06-17-2004 08:54 AM
