Hydraulic Crimping Tools & converting to AWG? - SailNet Community
 1Likes
post #1 of 20 Old 08-30-2015 Thread Starter
I'll have a small project that needs four #2AWG lugs crimped, and while I could order to cables from genuinedealz, I though maybe by no Amazon would have a hydraulic crimper that had AWG not mm2 dies.
Nope.
The mm2 dies always are too loose for AWG wires. The worst being maybe #6AWG where about 13.3mm2 is expected to crimp tight in a 15mm2 die?
Now, I can see that if our "SAE" crimping cups are thicker walled than the mm2 ones in China are, the finished crimp could still match up. And I appreciate that lugs and dies (the tool) should come from the same matching source, in the best of worlds.
But I'm wondering if those "loose" mm2 dies could be made a bit tighter, converted to AWG sizes, by simply grinding a little bit off their mating edges, so that the dies "overbit" and simply crimped down a little tighter than they were designed to? Making them right for AWG die sizes.
I know, nuisance time with a grinder. But I've go the grinder, and only need to grind one die, once in a long time, so there's not a lot of extra work to just do each one when and as needed.
Not totally mad?
I don't mind ordering in crimped cables...I'd just like to have the tool in hand, on site, for the times when ordering in would just hold a project up by a week.
hellosailor is offline
post #2 of 20 Old 08-30-2015
mitiempo's Avatar
Re: Hydraulic Crimping Tools & converting to AWG?
Easiest and probably best solution is to order the correct tool for the job.
Heavy Duty Crimping Tool for Battery Lugs & Terminals 6 AWG - 250 MCM Genuinedealz.com
Brian
mitiempo is offline
post #3 of 20 Old 08-30-2015 Thread Starter
Sure. A huge $240 tool for four crimps.
What's "right" for tradesmen using it every day, is often not economically feasible, no particularly desirable, for occasional use.
Not the first time someone here has said that, is it?
post #4 of 20 Old 08-30-2015
Over Hill Sailing Club
smurphny's Avatar
If a bit of grinding will do it, why not? How about a Swage-it tool? I've done large electrical crimps with one of those. The #8 hardened bolts on those can exert lots of pressure, more than the metal can take before it extrudes and probably as much as any $250 crimper.
smurphny is offline
post #5 of 20 Old 08-30-2015 Thread Starter
I've got one of the swageits, or something similar...IIRC this one is actually a tool for flared plumbing fittings (G) so grinding them down to AWG sizes would be a bit more work. Anyway, that's in the plumbing box, not a boat box.
post #6 of 20 Old 08-30-2015
smurphny's Avatar
I think the largest swage hole on those tools is .25, pretty close to a #2 AWG wire. Might be just right?
smurphny is offline
post #7 of 20 Old 08-30-2015 Thread Starter
Dunno. Also remember that you need to allow for the thickness of a "standard" lug itself, not just the wire. And every maker seems to just say "Use our lugs with our tool" rather than discuss whether there are any standards.
So you take a dull chisel and a maul...(G)
post #8 of 20 Old 08-31-2015
smurphny's Avatar
I've never been able to justify buying one of those expensive crimpers just to do an occasional cable end either. Sometimes you just have to make something functional and forego "perfect."
smurphny is offline
post #9 of 20 Old 08-31-2015 Thread Starter
"Sometimes you just have to make something functional and forego "perfect." "
Only if you're a pragmatic Yankee. (WEG)
post #10 of 20 Old 08-31-2015
I've used the nicopress swage tool on electric cables and it works pretty well, but not a "perfect" crimp. The bench mounted one at your local West Marine is quick and easy, especially of you bought the wire or lugs there. They might get a little upset of you brought your own parts in to do it.
capt jgwinks is online now
Volvo Hydraulic Transmission. F&C 44 tackorjibe Announcements and Suggestions Box 0 12-03-2012 07:23 PM
solar panel wire size (8 awg wont fit) and mounting question funjohnson Electrical Systems 5 06-05-2010 06:29 AM
Crimping 2/0 lugs SteveInMD Electrical Systems 7 08-21-2009 07:19 PM
VHF Coax AWG Tqxin Gear & Maintenance 4 11-21-2008 06:12 PM
Useful links, tools & tips suresh General Discussion (sailing related) 4 05-29-2006 05:20 AM
