Splitting Shore Power Cable - Page 2 - SailNet Community
 2Likes
post #11 of 15 Old 09-01-2015
overbored's Avatar
Re: Splitting Shore Power Cable
Originally Posted by sailak View Post
If the inverter is off I have no AC in the boat.
if you have no AC without the inverter then how do you run the charger.
"GOLD RUSH" PRINDLE 16
overbored is online now
post #12 of 15 Old 09-01-2015
bigdogandy's Avatar
Dock
Assuming your shore power comes in to a breaker panel with a feed from the panel to the inverter, is there a spare breaker you can use to feed a circuit for a convenience outlet or two?
Andy
Cruising
S/V Everlasting Moon
1981 Endeavour 32
Be joyful though you have considered all the facts.
- Wendell Berry
bigdogandy is online now
post #13 of 15 Old 09-01-2015 Thread Starter
Crealock 37
sailak's Avatar
Dock
Exactly. The inverter, or more correctly the Heart 10 Invertor/Charger, must be on.
Dale
S/V Elnora
Pacific Seacraft "Crealock" 37 #312
sailak is offline
post #14 of 15 Old 09-02-2015
Mold would be pretty unusual in the dead of winter in the northern latitudes, unless you already have an active colony. Cold winter air can't hold much moisture, so it's naturally dry.
Most marina's around here won't allow a boat to be plugged in, on the hard, while away. Batteries only need to be topped up every 4 to 6 weeks, assuming they are fully disconnected and not drained by parasitic load. We also put Kanberra Gel aboard, which seems to work best in closed unvented environments. All cabinets are opened and about a dozen buckets of Dry-rid are placed around in the sinks, etc. She is vented with fresh, cold, dry air, each time we stop by to top charge the batts.
Jeanneau 54DS
Minnewaska is offline
post #15 of 15 Old 09-02-2015
I would be a bit reluctant to make a Y connection in the shore power cord, as it is then far less weather-proof. It could even be a serious safety hazard.
Far better to do your connection inside the boat, and have an unbroken shore power cable.
MarkSF is offline
Shore power - Reverse Polarity and no power at GFCI outlets tatracy Electrical Systems 17 05-20-2014 10:58 PM
Hooking 110 power cord to shore power? dvuyxx Electrical Systems 16 06-02-2012 09:35 AM
50 amp shore power cable brokesailor Gear & Maintenance 2 07-26-2011 11:56 AM
Garmin power cable sailhog Electronics 1 04-17-2011 01:54 PM
[email protected]$%!%!! Shore Power! SEMIJim Gear & Maintenance 30 08-17-2007 12:58 PM
