Battery blues - Page 3 - SailNet Community
 2Likes
post #21 of 26 Old 11-17-2015
mitiempo's Avatar
Re: Battery blues
Originally Posted by joyinPNW View Post
I've read all of Mainesail's how-to's but it's been a little while-thanks for reminding me to go back and read them over again!
My mechanic emailed and recommended the Pronautic P Series battery charger. I've looked at reviews and they seem solid.
Excellent charger.
Brian
mitiempo is offline
post #22 of 26 Old 11-17-2015
Re: Battery blues
I've got a 10A one for my 24V bank and agree that it's a great charger and a great value. I also agree with Maine's recommendation to upsize to get the larger electrical connectors.
IStream is offline
post #23 of 26 Old 11-17-2015 Thread Starter
landofrainandgray
joyinPNW's Avatar
Re: Battery blues
^Do you mean buy a larger charger, or larger wiring from the charger to the battery? With our house battery at 225 ah, we ordered a 20 amp charger. Does that seem correct? Or, are you suggesting we go up to the next offering, a 40 amp?
Joy
Folie a Deux
PNW
joyinPNW is offline
post #24 of 26 Old 11-17-2015
Moderator
Maine Sail's Avatar
Re: Battery blues
The 20 and smaller ProNautic P chargers (Sterling ProCharge Ultra too) have small terminals and this makes for a bit tougher proper size wiring terminals. The 30A and above have much larger and more robust terminals. The article below will explain it in a bit more depth.
Installing A Marine Battery Charger
joyinPNW likes this.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #25 of 26 Old 11-17-2015
Old enough to know better
Re: Battery blues
So- here is the latest based on the mechanic's assessment today:
His recommendations: New battery charger (he says he's not a fan of the Xantrax and is sending me info on the type he recommends that work well with AGM batteries), new starter battery, and new house battery. He does not sell these and I trust he wouldn't recommend them unless necessary.
I have seen it here a few times "Friends don't let friends buy Xantrax"
1976 C&C 33
Project boat, lots of work to be done!
miatapaul is offline
post #26 of 26 Old 11-17-2015
Re: Battery blues
Would it be possible to use some sort of "speaker pin connector" to hook up the thicker cable without loosing too much capacity?
Parts Express Gold 12 AWG Speaker Pin Compression Connector Pair
Edit:
Never mind, they are posts that need a ring connector. I thought they were cable clamp type.
1976 C&C 33
Atomic4 Blues SirRedemption Atomic 4 11 02-17-2013 04:54 PM
Greywater Blues oz_hole Gear & Maintenance 10 10-28-2007 12:55 PM
Reapir blues geedunk Hunter 0 04-23-2007 11:50 PM
Crew Blues sailnaway General Discussion (sailing related) 37 07-21-2006 03:19 PM
Diesel Blues z1nonlyone Gear & Maintenance 3 03-22-2004 04:18 PM
