solar panels - Page 2 - SailNet Community
 9Likes
post #11 of 15 Old 12-30-2015
Lake Sailor
cb32863's Avatar
Re: solar panels
Originally Posted by jlt1149035 View Post
Hi,
Harbor Freight sells 1.5 watt ($15.00) solar charges. I have used it to maintain a car battery when we are away for extended amount of time. What I want to do is use them as a back up for my boat battery over the winter should we lose power as I keep the boat in the water. She is a 1958 wooden boat and takes on some water, need the pump to work.
Thank you for your help,
Joe
You're going to need more than that little panel for that.
Start here Installing A Small Marine Solar System Photo Gallery by Compass Marine How To at pbase.com
Umquam Porro
Seeker 1992 Beneteau First 235
cb32863 is online now
post #12 of 15 Old 12-30-2015 Thread Starter
Re: solar panels
Gary,
I did not mean to run the pump, just keep the battery up if the power failed
Joe
jlt1149035 is offline
post #13 of 15 Old 12-30-2015
Lake Sailor
cb32863's Avatar
Re: solar panels
Gary,
Joe
Still will not be enough....
Paging Maine Sail.... Maine Sail expertise required in this thread.....
Umquam Porro
post #14 of 15 Old 12-31-2015
deltaten's Avatar
Send a message via Yahoo to deltaten
Re: solar panels
anecdotal evidence; but.......
A Bud runs HF rig at camp Takes a 5 w roll-up panel eight hours to fill a set of AA batts in his handheld ! A seperate 15 w panel to recharge his small (30Ah ?) gel for running the vehicles transmitter takes several hours of brite sun to get it going again; not necessarily filled to the brim.
A 15 w panel is ner to 1 A. A regular car charger on 2 A setting takes *how* long to refresh a dead group 24-7 batt enuff to stat car?? Granted; a started take a helluvva lotmore juice tthan a bilge pump; but that's one item ( the pump) I wouldn't want to go begging for power !
HTH,
Paul
S/V Chrysalis
'80 Watkins 27
North East, MD
deltaten is offline
post #15 of 15 Old 12-31-2015
Moderator
Maine Sail's Avatar
Re: solar panels
Hi,
Joe
$10.00 per watt is really quite expensive..... That said even in optimal conditions a 1.5W panel is only capable of producing 0.12A. This is barely enough to keep up with self discharge in warm weather let alone a bilge pump or stereo memory or what ever else is bleeding on the system. If the batteries were fully charged and fully isolated then a 1.5-3W panel could "maintain them" in cool weather. A 10W panel would be a far better "maintainer" and you should be able to find one for under $3.50 per watt or a far better deal and HF....
______
-Maine Sail / CS-36T
Maine Sail is offline
SOLAR JACK solar panels? christian.hess Electrical Systems 14 08-24-2016 10:55 AM
Solar Panels safira Gear & Maintenance 6 12-12-2013 08:51 AM
Solar deck instead of solar panels ulferlingsson Gear & Maintenance 34 01-31-2013 05:03 AM
Anyone bought solar panels from Sun Solar? justonemoreproject Electrical Systems 1 04-18-2012 05:08 PM
Solar Panels bottleinamessage Jeanneau 0 08-16-2007 07:10 AM
