New boat/battery question - Page 3 - SailNet Community
 14Likes
post #21 of 24 Old 02-26-2016
Stu Jackson's Avatar
Re: New boat/battery question
Originally Posted by Irunbird View Post
Thanks, Stu- I'm working on sourcing them now.. It's a bit problematic here in Florida, but the boat is not yet in my back yard so I've got time.
Ray
Ray, I googled US Battery or American Battery out here and found their distributor's warehouse, bought them there right of a brand new pallet. You might try that method instead of just a reseller.
I have (3) Grp31 for 390 ah. Been doing this for 18 years.
Good luck.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #22 of 24 Old 03-03-2016
Argyle38's Avatar
Dock
I have a fair number of Firefly batteries out there and a lot more scheduled to be installed. I buy my Firefly batteries From Bruce at Ocean Planet Energy but he has a number of distributors. If you are in the Chess Coastal Climate Control is also a Firefly dealer.
From your customer base that has these installed, have you started to get a feel for the expected longevity of these batteries, either in year or number of cycles? Or, have you tested any yourself?
If they are designed to go 'really' deep in the cycle and operate under PSOC, then what sorts of failure mechanisms remain? Heat only?
If they significantly outlast other AGM's, then their economy becomes obvious.
Thanks!
-Argyle
S/V Argyle
Downeaster 38 #40
Argyle38 is offline
post #23 of 24 Old 03-03-2016
Super Moderator
Maine Sail's Avatar
Thanks!
-Argyle
I was one of the first in the marine industry to have a Firefly, Nigel was the other. Nigel's experience parallels what I have seen. He is using his on his own boat and I have been beating the piss out of mine in my in my shop/lab/test bench as well as on my own boat last year..
When I got the battery I was sure carbon foam was another BS fad and I set out to try and prove that. So far the battery is winning.
Nothing I have done to it has resulted in a loss of capacity.
-- That battery was used in the Practical Sailor PSOC testing. It survived with all its capacity when no other AGM did.
-- After the PSOC testing the battery was left to sit for three months after a discharge to 20% SOC in temps between 90F and 70F. It recovered all its capacity.
-- It has had no less than 40 complete discharge capacity tests to 10.5V and still has all its capacity.
-- It has undergone nearly 100 cycles to 80% DOD and it still has all its capacity.
-- I took it "car camping" with the kids, installed on my brother-in-laws camper (his battery was dead) and we used an inverter off it. By day three the inverter kept shutting down on low voltage.. The kids kept turning it on and it would eventually hit low voltage again and shut off. LVC on that inverter is 10.7V. It was four weeks before my brother-in-law got the battery back to me, at a resting voltage of 11.1V. I charged it, cycled it, charged it and tested Ah capacity and it still had all its capacity...
-- It was used on my own boat last year and never charged beyond 13.8V, which is my LiFePO4 batteries charge voltage. Despite 9 months of never seeing more than 13.8V, for about 20 minutes at a time, the battery still has all its capacity.
-- This winter it has undergone another 42 cycles to 11.7V and still has all its capacity..
So to answer the question, yes I have tested it...
While I certainly don't have long term data what I have seen thus far is darn impressive. I've not seen any lead acid battery perform like this.
______
-Maine Sail / CS-36T
Maine Sail is offline
The Following User Says Thank You to Maine Sail For This Useful Post:
Argyle38 (03-03-2016)
post #24 of 24 Old 03-03-2016 Thread Starter
Irunbird's Avatar
I have never seen any lead acid battery perform like this. Doing what I have done to this battery is murder for every other AGM out there....
Ok, ok- we get it.. they're phenomenal batteries. Sheesh!
It will probably be overkill, but I want them.
Irunbird is offline
Battery question matthewwhill General Discussion (sailing related) 4 06-26-2014 08:19 AM
battery question northstarjim Gear & Maintenance 14 07-01-2008 04:55 AM
sorry, another battery question Newport41 Gear & Maintenance 8 02-16-2007 02:58 AM
battery question... marinesniper Learning to Sail 17 08-17-2006 10:09 PM
Battery question dch Gear & Maintenance 1 07-05-2005 05:29 AM
