Wiring Diagram feedback - Page 3 - SailNet Community
 6Likes
post #21 of 35 Old 09-02-2016
Bleemus's Avatar
Re: Wiring Diagram feedback
Thank you MaineSail.
Sent from my iPad using Tapatalk
Keth
Boat Vinyl Lettering and Graphics
Bleemus is online now
post #22 of 35 Old 09-03-2016
Maine Sail - Have you blown a fuse? That "wiring diagram" is completely wrong. I'm not familiar with the Victron shunt. I suppose it has some active circuit unlike a conventional shunt. But a drawing that connects wires at terminals that are not actually connected is useless. Is that how you work? I dont think so. So i guess with all sorts of dangerous assumptions the drawing can be understood...
"...there are two kinds of opinions, those based upon tradition ... and those having something in their favor." B. Russell
aloof is offline
post #23 of 35 Old 09-03-2016
Super Moderator
Maine Sail's Avatar
Not blown a fuse at all and I find your personal level insul/rudeness unwarranted and un called for.
I see MUCH, MUCH worse diagrams from actual boat builders all the time.
It would be nice if you actually tried to help the OP instead of just slamming his diagram as "completely wrong".
I would challenge you to point out every detail that is "completely wrong" so that he can correct it. Better yet download it into MS Paint and draw in the corrections for him. That would be helpful, bashing his diagram and claiming it is "completely wrong" without also providing detail of where exactly it is "completely wrong" is pretty much of no help to him.
Sadly his diagram skills are actually better than many of the boatbuilders out there.
Let's focus on specifics so we can help each other..
______
-Maine Sail / CS-36T
Maine Sail is offline
post #24 of 35 Old 09-03-2016
valis's Avatar
The house battery (+) is shown connected to the shunt. In the diagram, the shunt shows four terminals. I would expect the outer terminals to be wired between the battery (-) and the ground bus. The two inner shunt terminals would be the sense terminals and be connected via the twisted pair wire to the monitor.
This is probably not what the OP intended to convey, but to make things clear, the battery (+) needs to be connected to the battery monitor. So do the shunt sense wires. The monitor probably also needs an independent ground-bus connection.
In the diagram,the echo charger and the solar controller (+) terminals show two wires apparently connected, where I believe there are actually independent terminals. There should be an input and an output (and a ground), and the diagram does not make this clear. The batteries show similar connection symbols, but I believe these are true connections.
Paul Elliott
S/V VALIS - PSC 44 #16 - Friday Harbor, Washington
valis is offline
post #25 of 35 Old 09-03-2016
Your refer pulls 6 amps when running. You need 160 amps per day.
On my Endeavour 42, my refer pulls 10 to 12 amps when running yet I dont consume 160 amps per day. I did add a bit of blueboard insulation to the freezer and squirted some foam insulation into the frig/freezer walls. Actually, a lot of foam, I was surprised at how much the cavities took easily. I would look at whether you really are pulling 160/day and whether you can do some insulation upgrades. Do you see condensation on any exterior refer surfaces? If so, you have poor insulation there.
I have 4 solar panels for 480w total. And I have a 750 amp house battery bank. A bigger bank wont work as hard. I ripped out the old battery box and rebuilt it, I found a lot of wasted space below which I used by installing tall batteries, Trojan T-1275s
xort is offline
post #26 of 35 Old 09-03-2016
Super Moderator
Maine Sail's Avatar
The victron shunt uses a shunt mounted PCB and a UTP data cable, that sends power and voltage data to the the monitor.
What he conveyed is a decent representation of how the Victron shunt gets wired... If he had added wire gauges to the diagram and the fuses, he did clearly label the UTP cable, it would be more accurate. For anyone that has installed a Victron shunt they would know what he was conveying rather easily.
Victron Shunt
______
post #27 of 35 Old 09-03-2016
aeventyr60's Avatar
Not sure why your/ the Op's refer would be running 24 hours a day? Don't you have a thermostat? My Danfoss unit has about a a 60 percent duty cycle. On for six minutes, off for four minutes. I can actually tweak it a bit to run more or less depending on my available power.
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is offline
post #28 of 35 Old 09-04-2016
valis's Avatar
OK, fair enough. I was looking at the schematic as being more generic, given the lack of detail (yes, I know the battery monitor model # is called out in the sidebar but I am not personally familiar with the associated shunt).
I believe my comment about the echo-charge connections is still valid, as is my general observation about the confusing module connection diagrams.
I suppose the objective should be to critique the intended design, rather than the schematic style, but to do this safely we need a minimum of schematic ambiguity.
Paul Elliott
valis is offline
post #29 of 35 Old 09-04-2016
Mermaid Hunter
SVAuspicious's Avatar
Units are important. Failure to get the units right indicates, to me at least, either sloppy thinking or a failure to understand.
Amps / day for example is a meaningless term (a measure of accelerating current only applicable to discussions of inrush current and would then be in terms of milliseconds and not days).
Amperes (amps or A) are a measure of current (coulumbs/second).
Amp·hours (Ah) and Watt·hours (Wh) are measures of energy.
In discussing energy capacity or consumption it is helpful to talk about energy per unit time - usually Ah/day on boats, kWh/month in homes.
Getting the units right aids understanding and communication.
SVAuspicious is offline
post #30 of 35 Old 09-04-2016 Thread Starter
bigdogandy's Avatar
Location: Splitting time between Merritt Island, Fl and Asheville, NC for a bit
Dock
My fridge does have a thermostat, and probably runs on a 70% on / 30% off cycle due to the size of the box (10 cf) and the small amount of insulation that is there. One of my next projects is to reduce the size of the box with added insulation.
My AH /day calculations were based on fairly conservative estimates of usage....Would be curious to learn what your average consumption is, if you track that.
Andy
Hard Aground
S/V Everlasting Moon
1981 Endeavour 32
Be joyful though you have considered all the facts.
- Wendell Berry
bigdogandy is online now
Wiring Diagram Navyret56 Electrical Systems 2 01-30-2015 01:41 PM
wiring diagram and questions boz86 Electrical Systems 8 09-14-2013 03:35 PM
Need wiring diagram Cyane Sailboat Design and Construction 3 08-05-2012 02:53 PM
Wiring diagram needed old-sailer C & C 1 05-28-2012 08:42 AM
redwing 30 wiring diagram irtrimble C & C 0 12-23-2007 06:08 PM
