Wiring Diagram feedback - Page 4 - SailNet Community
 6Likes
post #31 of 35 Old 09-04-2016
aeventyr60's Avatar
Re: Wiring Diagram feedback
It's roughly 60 amp hours per day. The compressor is a Danfoss BD 35. The thermostat has a 677 resistor so the compressor runs at 2500 rpms.
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is offline
post #32 of 35 Old 09-04-2016 Thread Starter
bigdogandy's Avatar
Location: Splitting time between Merritt Island, Fl and Asheville, NC for a bit
Dock
Not blown a fuse at all and I find your personal level insul/rudeness unwarranted and un called for.
I see MUCH, MUCH worse diagrams from actual boat builders all the time.
It would be nice if you actually tried to help the OP instead of just slamming his diagram as "completely wrong".
I would challenge you to point out every detail that is "completely wrong" so that he can correct it. Better yet download it into MS Paint and draw in the corrections for him. That would be helpful, bashing his diagram and claiming it is "completely wrong" without also providing detail of where exactly it is "completely wrong" is pretty much of no help to him.
Sadly his diagram skills are actually better than many of the boatbuilders out there.
Let's focus on specifics so we can help each other..
Thanks Maine Sail - for background, I'm a construction guy, training as a carpenter and not an electrician, but I've learned a lot from this forum (and others) and from the tutorials on your awesome site. I appreciate everyone's input on this project and will clean up the diagram when I get back home. Enjoying a day on the boat today, though!
Fair winds everybody.
Andy
Hard Aground
S/V Everlasting Moon
1981 Endeavour 32
Be joyful though you have considered all the facts.
- Wendell Berry
bigdogandy is online now
post #33 of 35 Old 09-10-2016 Thread Starter
bigdogandy's Avatar
Dock
OK - here's a stab at a cleaned up diagram.....I am still working on details of wiring the alternator regulator into the system - unfortunately the schematic provided with the kit from Electromaax leaves a lot to the imagination!
Andy
Hard Aground
1981 Endeavour 32
- Wendell Berry
post #34 of 35 Old 09-11-2016
Originally Posted by bigdogandy View Post
My fridge does have a thermostat, and probably runs on a 70% on / 30% off cycle due to the size of the box (10 cf) and the small amount of insulation that is there. One of my next projects is to reduce the size of the box with added insulation.
My AH /day calculations were based on fairly conservative estimates of usage....Would be curious to learn what your average consumption is, if you track that.
My 1985, poorly insulated freezer with spillover frig is biggrr than that. I added an inch of blue foam sheet insul to the freezer and sprayed foam in the rest of the cavities. I draw roughly 120 amps per day, a bit more in toasty conditions. Its an old style seafrost with 2 holding plates. I did add their computer controller. I keep the freezer at 22 degrees near the top and 10 degrees near the bottom.
Again, do you see condensation on any exterior surfaces including the hull? Thats a sign of very poor insul and a shot of foam can really help,even if temporarily.
xort is offline
post #35 of 35 Old 09-11-2016 Thread Starter
bigdogandy's Avatar
Dock
I don't see condensation on any of the surfaces that are visible, but most of the box is hidden behind other cabinets dividers so it's hard to say for sure. There is a near constant trickle of condensation that goes into the bilge, so there must be some leaky spots at least. Installing additional insulation and reducing the overall size of the box are one of the next steps, and if that doesn't do it I've got to consider either replacing the refrigeration unit or look at an Engel or equivalent.
Andy
Hard Aground
1981 Endeavour 32
- Wendell Berry
Wiring Diagram Navyret56 Electrical Systems 2 01-30-2015 01:41 PM
wiring diagram and questions boz86 Electrical Systems 8 09-14-2013 03:35 PM
Need wiring diagram Cyane Sailboat Design and Construction 3 08-05-2012 02:53 PM
Wiring diagram needed old-sailer C & C 1 05-28-2012 08:42 AM
redwing 30 wiring diagram irtrimble C & C 0 12-23-2007 06:08 PM
