"Not an electrician" needs wiring critique. - Page 2 - SailNet Community
 4Likes
post #11 of 46 Old 11-22-2016
Mermaid Hunter
SVAuspicious's Avatar
Re: "Not an electrician" needs wiring critique.
*If your dock offers 15A or 20A 120V AC simply use an extension cord for the battery charger, when dockside, and plug directly into the charger.
I can't remember the last time I disagreed with RC but this comment makes me uncomfortable. No issue as long as you are on the boat. Leaving a conventional extension cord connected when you leave is counter to ABYC recommendations and manufacturers specifications for the cord. If your marina is paying attention they'll be unhappy since it will violate the terms of their facility insurance.
SVAuspicious is offline
post #12 of 46 Old 11-22-2016 Thread Starter
smitty225's Avatar
Ok....I'll draw this up and resubmit.
smitty225 is offline
post #13 of 46 Old 11-22-2016 Thread Starter
smitty225's Avatar
My current AC configuration is like this:
AC Shore Power --->(2) 15amp Outlets.-->battery charger
So, the battery charger is plugged into one of the 15amp outlets. No need for the long extension cord.
post #14 of 46 Old 11-22-2016 Thread Starter
smitty225's Avatar
How is this one:
The Following User Says Thank You to smitty225 For This Useful Post:
eherlihy (11-22-2016)
post #15 of 46 Old 11-22-2016
Bleemus's Avatar
That looks much simpler and easy to troubleshoot. Am sure I am missing something and will let the pros chime in but you are on the right track. I would take the suggestion of combining the two batteries and going to a simple single circuit Off/On switch.
Sent from my Pixel C using Tapatalk
Keth
Boat Vinyl Lettering and Graphics
Bleemus is online now
post #16 of 46 Old 11-22-2016 Thread Starter
smitty225's Avatar
That battery switch in the diagram is already in the boat. I don't see the need to replace it. I'll just use it in "both" or "off."
post #17 of 46 Old 11-22-2016
Super Moderator
Maine Sail's Avatar
If they have a properly wired marina, and the pedestal offers a GFCI protected 15A or 20A outlets, there is nothing in the ABYC or NEC that prevents an owner from plugging an extension cord directly into a battery charger that is designed for that purpose. We have hundreds of thousands of boats in the US that have only an AC battery charger but no 30A service, just a pig-tail charger. We also have many marinas that have only 15A or 20A receptacles for catering to runabouts and lake boats.
If your marina does not offer 15A or 20A GFCI protected outlets, at the pedestal, then you do not want to do this. You also DO NOT want to to plug your boat into a 30A NEMA L5-30 to straight blade "adapter" that steps 30A service down to straight bladed extension cord....
A dock with 15A or 20A receptacles, if wired to code, will be protecting those outlets with 15A or 20A breakers and a GFCI outlet, much safer by comparison to a 30A adapter suicide plug.. Using a 30A NEMA L5-30 to straight bladed adapter now means your 14GA or 12GA extension cord is now protected by a 30A breaker, and this is BAD news.
Is this an "ideal" scenario", no not at all, but there is nothing in the codes or safety standards that precludes it if the dock is correctly wired for 120V 15A or 20A outlets. This would be considerably safer than an owner creating a dangerous on-board wiring situation, with a non-marine inverter, missing safety Earth grounding and incorrect wiring practices that could kill someone.
In a marina with only 30A or 50A service extension cords and adapters, to get to straight bladed extension cords, should be banned by the marina. The use of 30A to 15A or 20A straigth blade is what is dangerous because of incorrect OCP for teh cord being used.
Again I only recommend this for a vessel where the dock is already properly wired for 15A or 20A 120V GFCI protected outlets not when a 30A to 15A or 30a to 20A adapter is required..
jdubbery likes this.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #18 of 46 Old 11-22-2016
Super Moderator
Maine Sail's Avatar
Your current shore power does not meet ANY safety standards...
This is the easiest schematic for a basic AC system that also meets the applicable safety standards.
______
post #19 of 46 Old 11-22-2016
Super Moderator
Maine Sail's Avatar
How is this one:
In regards to AC....... NO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
______
post #20 of 46 Old 11-23-2016
Mermaid Hunter
I defer to your knowledge of ABYC but I'm pretty sure the NEC does not approve that Home Depot/Lowes/WalMart extension cord for submersion. If the hundreds of thousands of boats using extension cords never end up with the extension cord in the water I'll be very surprised.
From a practical point of view straight blade connectors are not mechanically secure. Ignore the fact that 99.5% (I made that number up - almost all) of outlets are upside down. A straight blade connector not fully seated is a safety hazard. Twist-lock and even SmartPlug are better even if not perfect. I rather like ring terminals and machine screws myself, but hey that's just me. *grin*
That doesn't make it a good idea for unattended applications.
Agreed. I built a breaker box for my adapter.
"Seacock" vs. "ballcock" or "ball valve?" SEMIJim Gear & Maintenance 18 09-02-2013 06:31 PM
VIDEO: Coast Guard Academy Welcomes "Blue Goose" and "Stormy Petrel" - Patch.com NewsReader News Feeds 0 07-28-2012 08:50 AM
C270 Main Sail "stack Pack", Quick Cover", "lazy Bag" Install randy22556 Catalina 1 02-28-2007 12:53 PM
