SIX weeks and zincs are TOAST - Page 6 - SailNet Community
 21Likes
post #51 of 60 Old 05-30-2019
Super Moderator
Maine Sail's Avatar
Re: SIX weeks and zincs are TOAST
Originally Posted by Don0190 View Post
Is your boat "bonded"? If so do you also have metal tanks or things connected to the ground circuit? If you do check to be sure all those grounds are in good condition or things like a fuel tank level monitor will pass current into the bonding etc and out the shaft to the water
Typical marine fuel tank senders are a simple resistance device and don't use or need +12V power to do their job in sending a resistance measurement to the fuel gauge.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #52 of 60 Old 05-30-2019 Thread Starter
Learning the HARD way...
eherlihy's Avatar
Part of the problem was that the 12VDC Facet Fuel Pump was using the same lug as the fuel sender as the negative *and* the bonding wire. (See my ABYC references above). The fuel pump WAS sending power into the bonding circuit every time that it was energized.
I have since separated the bonding and the negative circuits.
@overbored 's post makes me so happy that I don't have a saildrive.
USCG Licensed OUPV Captain, ASA 101/103/104/105/106/114/118 Instructor - Also certified in Marine Electrical Systems
eherlihy is online now
post #53 of 60 Old 05-30-2019
colemj's Avatar
The capacitance and hall effect ones do. Ones like this, for example (we have them): CENTROID PRODUCTS - Computerized Tank Display - Electronic Senders - capacitive fuel gauges
Mark
Dolphin 460 Catamaran "Reach"
- Current boat
- Previous boat
colemj is offline
post #54 of 60 Old 05-30-2019
Super Moderator
Maine Sail's Avatar
Mark
Precisely why I said "typical".. Most production boats have a Moeller/Tempo type then the next most common we see is a Wema/KUS type.
______
post #55 of 60 Old 05-31-2019
Location: The house is in Kingsport, TN. Boats are on Watauga Lake and in New Bern, NC
I don't understand. How does the gauge on my dashboard measure the resistance of the variable resistor in the tank without sending a current through the variable resistor? Doesn't there have to be a current flowing into the sender's spade fitting and back out through the body of the sender in order to measure its resistance?
What is actually inside of the marine gauge on my dash? Google can find some stuff about automotive gauges, some quite detailed like SW-EM Fuel Gauge for an old Volvo, but seems to find nothing for marine gauges. That site shows maximum sensor voltage occurs at the empty tank condition: 5.3V and maximum sensor current occurs at the full tank condition: 76.6mA
Bill
wsmurdoch is online now
post #56 of 60 Old 05-31-2019
Super Moderator
Maine Sail's Avatar
Bill
Clearly I should have been more clear. You will not see 12V+ on the sender wire (battery level voltage) in a typical marine fuel, oil pressure, temp etc. gauge. If you do measure 12V +/- there is most likely a problem with the gauge. With the gauge powered, if you measure between "S" and the neg bus, you should see 8V or less but not 12V.
eherlihy likes this.
______
post #57 of 60 Old 05-31-2019
bell ringer
Don0190's Avatar
Guess in a few months we will know the answer. Till then it is all theory.
Don't blow air up my rear, be useful and blow it at the sails!
Don0190 is online now
post #58 of 60 Old 07-04-2019 Thread Starter
eherlihy's Avatar
7/4/2019 UPDATE:
Happy 4th of July!
During my annual Independence Day Cruise with The Admiral, we went from Warwick RI to Cuttyhunk MA to Westport MA to Bristol RI. On the way from Westport to Bristol we stopped at Third Beach where the water is relatively clear, and the water temp was above 70ļF. I dove in to check the anodes, and to see if there was any damage from the lobster pot that we picked up on the rudder while leaving Cuttyhunk. I am pleased to report no damage to the rudder, and the anodes look GREAT! Once again @Don0190 had it EXACTLY correct in Post #40. (Makes me wonder if he was messing with my boat...)
RegisteredUser likes this.
post #59 of 60 Old 07-04-2019
bell ringer
Don0190's Avatar
Originally Posted by eherlihy View Post
]Don0190 had it EXACTLY correct in Post #40. (Makes me wonder if he was messing with my boat...)
Tell me the boat name, model, hull number and Iíll check my records. You know I used to sail out of Salem right ?
Uncle Bob the 1st likes this.
post #60 of 60 Old 08-03-2019 Thread Starter
eherlihy's Avatar
8/3/2019 update:
I sailed the boat to Prudence Island and jumped in to inspect the anodes again today - 8 weeks after launch, and probably 100 engine hours this season. The anodes are still there and looking OK! More barnacles than I'm used to seeing, although the prop is clean, the anodes and the strut had a LOT of growth. I scraped this off with a putty knife, and all seems good. I can now confirm that the problem was that the bonding circuit and the battery negative were tied together at the fuel tank. Whenever the Facet lift pump was energized the anodes were bubbling.
Problem solved!
need help my brain is toast MrA Learning to Sail 37 10-16-2014 07:37 PM
Toast on an Origo redduke748 Cruising & Liveaboard Forum 6 01-02-2010 12:39 AM
A Toast for Teddy WanderingStar Politics, Current Affairs, Guns & HOT Topics 10 10-22-2009 05:40 PM
Fish Zincs, Pencil Zincs and stray current gcalahan Catalina 0 04-18-2007 08:27 PM
