SIX weeks and zincs are TOAST - SailNet Community
 15Likes
post #1 of 57 Old 10-18-2017 Thread Starter
Learning the HARD way...
eherlihy's Avatar
Exclamation SIX weeks and zincs are TOAST
After 9 weeks in the water, I had my boat short hauled on August 28. The zincs looked pretty bad so I replaced them with 2 brand new CAMP 1" zincs, and she went back in the water on the 29th. Fast forward six weeks, and I had the boat hauled and blocked for the winter this week and visited to winterize the freshwater system and take down the canvas, and a bunch of other things yesterday. I was curious as to how the zincs had held up so it was one of the first things that I checked out.
This is how they looked (this is flipped 90);
The boat lives on a mooring in brackish water (Greenwich Bay, RI) and has not been on shore power at all! I have done a couple of cruises and probably motored about 55 hours during those six weeks.
The shaft is stainless, and the prop is bronze. The bonding wire has been disconnected from the through hulls (yes - I know what I am risking), but is attached to the keel, the engine (and therefore the transmission and the prop shaft - no flex coupling) the mast, and the shrouds.
Right now, I am planning on replacing the zincs with aluminum anodes for next season.
Other ideas?
Thanks in advance!
USCG Licensed OUPV Captain, ASA 101/103/104/105/106/114/118 Instructor - Also certified in Marine Electrical Systems
eherlihy is online now
post #2 of 57 Old 10-18-2017
Moderator
Maine Sail's Avatar
Re: SIX weeks and zincs are TOAST
Time to bust out the reference cell and current leakage grade meter.... Even carbon/graphite packing or a PSS won't accelerate the erosion that badly. You have a DC leak there, and it's small, and will require meticulous tracing.
FWIW The day I launched, late may, all I had on hand were cheap CAMP anodes and they came out of the water just fine, on Monday, barely eroded...
______
-Maine Sail / CS-36T
Maine Sail is offline
post #3 of 57 Old 10-18-2017 Thread Starter
eherlihy's Avatar
Thanks!
Yes, I forgot to mention that I do have a PSS Shaft Seal.
post #4 of 57 Old 10-18-2017
Dirt Free
boatpoker's Avatar
Definitley a DC Leak, check the integrity of your bilge pump wiring first then any other conductors in the bilges if you don't have a reference cell..... then buy a cell
Good luck.
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is online now
post #5 of 57 Old 10-18-2017
Bleemus's Avatar
Plop plop fizz fizz!
Keth
Boat Vinyl Lettering and Graphics
Bleemus is offline
post #6 of 57 Old 10-18-2017 Thread Starter
eherlihy's Avatar
Good luck.
Thanks!
There are no wires in the bilge, except for the bonding and about two feet of bilge pump wires. There is no water in there either.
This is what the zincs looked like in August, after 9 weeks.
I guess that there isn't much that I can do about it now, as the boat is on the hard for the winter
It looks like a reference cell, and a new DVM is in my future.
post #7 of 57 Old 10-18-2017
Dirt Free
boatpoker's Avatar
Gotta love a clean dry bilge.
post #8 of 57 Old 10-19-2017 Thread Starter
eherlihy's Avatar
I do...
I have an idea of what the problem is. I upgraded the alternator to a 90 amp when I bought the boat. I simply swapped the alternator and replaced the wire without looking at the wiring layout. Two years ago I reconfigured the battery banks into a 220ah house bank. Last year I added 12v refrigeration, and moved from a slip to a mooring.
The alternator negative lead is AWG 8 that runs to the engine block. I had also added an AWG 2 from the other side of the engine block to the negative bus bar.
I should have run an AWG 2 from the bus bar to the alternator.
post #9 of 57 Old 10-19-2017 Thread Starter
eherlihy's Avatar
My point is that prior to this year, the load on the battery bank was less, and the shore power charger was handling the load. Now, the alternator is doing all the work, and the inadequate wiring (through the block) is showing its limitations.
post #10 of 57 Old 10-19-2017
snokid's Avatar
I don't have this problem but I went to look up what a reference cell meter is, not sure what I'm looking for.
So
What is a reference cell meter?
thanks
Bob
snokid is offline
need help my brain is toast MrA Learning to Sail 37 10-16-2014 07:37 PM
Toast on an Origo redduke748 Cruising & Liveaboard Forum 6 01-02-2010 12:39 AM
Fish Zincs, Pencil Zincs and stray current gcalahan Catalina 0 04-18-2007 08:27 PM
