Solar heating element for water heater - Page 5 - SailNet Community
 17Likes
post #41 of 66 Old 11-27-2017
outbound's Avatar
Re: Solar heating element for water heater
Would note my House has solar hot water and solar for electricity. The solar hot water just runs our domestic hot water through a black panel which is sufficient to bring it up to 110f even on 20 degree short winter days. On cloudy or rainy days it at least boosts the tank temp up so less outside power is needed. We also sell power back to the grid year round so if you have enough panels short winter days aren’t the issue it’s made out to be.
I note this to point out solar hot water is much more efficient when the sun directly heats the water rather than making electricity then heating an element.
I would further note in the tropics we get equal power from wind as solar given the trades and short winter days. Summer in New England is 90% solar only 10% wind.
If his goal is hot water then get a panel for that purpose. We have 2 fairly large ones on our roof but I think they make smaller ones. Ours are very low tech and flexible. Easy to mount. Only control is thermostats to turn onor off that loop.
If his goal is a heat sink get a heat sink. If his goal is to not waste electricity put it a second abet smaller house bank and charge that.
s/v Hippocampus
Outbound 46
outbound is online now
post #42 of 66 Old 11-27-2017
aeventyr60's Avatar
From all the responses, while most helpful and interesting, I haven't heard anyone actually using, first hand, solar (in any way) to warm the tank. Sure seems like a product opportunity.
There you go, IF it was viable, and not to much of a drain on batteries, charging systems, then every cruiser I know, Including myself would buy, install, use and sing it's praises. We didn't just fall off the turnip truck out here...
john61ct likes this.
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is offline
The Following User Says Thank You to aeventyr60 For This Useful Post:
john61ct (11-28-2017)
post #43 of 66 Old 11-28-2017
colemj's Avatar
Originally Posted by dadio917 View Post
That's funny! 128 gallons!
I guess my point wasn't clear. The reference to 128gal was that in order to boil your 6gal tank dry, you would have to boil all of the water on the boat, because as the heater tank boiled off, it would be replenished with new cold water from your water tank.
The reason you aren't hearing about 12Vdc heater elements is that there are only 6 or so people on this thread replying, and most of them aren't cruising or do not have excess solar. Doesn't require a fall from a turnip truck. I know many people using them - they are very common on boats with windgens as load dumps. People with solar use them less so because most don't have excess solar, and solar can be regulated by just shutting off the controller output - unlike wind.
As I mentioned, they aren't terribly efficient, particularly for excess solar which is usually late in the day. However, they are viable, and people are using them. Many don't have AC power on board, so replace their tank elements with DC ones and take whatever excess DC comes their way to supplement their engine heat.
I read your post as asking about the possibility of putting some excess solar energy to use heating water and tried to focus answers on that. But it seems like the consensus is that you should have a solar shower, or a solar heat panel, or a heat sink, or a new battery bank. And that all of the cruisers I know using DC heating elements are gullible newbies being taken for a ride by the big corporations. It would seem that none of these responders actually used physics to come to their conclusions.
In a final attempt to actually be helpful, here is how to determine how much energy it takes to heat a gallon of water:
Q=mc∆T, where m=mass of water, c=specific heat of water, ∆T=change in temperature in Celsius. The resulting units will be in Joules.
Since the mass and specific heat is constant for water at sea level, this simplifies to Q(J)=(15,818)∆T. Converting to Wh for solar:
Q(Wh)=4.39∆T. Put another way: ∆T=(Wh of excess solar)÷4.39
Now, if you know how much extra solar power you have, you can easily determine how hot it will make your water.
For instance, if you have 300W of solar, and 3hrs/day to dedicate it to heating water, and the water is at 27C (I've moved you down to Mexico), then those 900Whr of solar will heat your 6gal of water to 135F. Of course, that is at nominal panel specs for the solar, so this should be adjusted to ~40% to accommodate late day sun and imperfect conversion. Given this, you can expect those 900Whr of solar to heat 6 gal of 80F water to 105F.
So the question is how much solar do you have, and how much excess do you expect?
The question is not which turnip truck you fell off.
Mark
CVAT likes this.
Dolphin 460 Catamaran "Reach"
- Current boat
- Previous boat
colemj is offline
post #44 of 66 Old 11-28-2017
JimsCAL's Avatar
A couple of thoughts.
A thermal solar panel is the more efficient way to heat water, at least compared to solar electric. One problem is you would need to run hoses between the water tank and the panel. Probably a difficult retrofit.
Another option no one has mentioned is a heat pump. That means using a refrigeration unit to do the heating rather than a resistance coil. Think of rejecting the heat from your refrigerator to the hot water tank rather than the air or the sea.
All this complexity is only of use if you are not running your engine, so at anchor etc. If you are motoring for any period, the water tank is already hot. Not sure it's worth the effort.
S/V First Tracks
1985 Cal 33-2
JimsCAL is offline
post #45 of 66 Old 11-28-2017
aeventyr60's Avatar
Here's something for the OP to by and test. Let us know how it works. If your still having that crap wx that I experienced on the 16th on Novemeber at SFO, then it's going to be a long winter...
https://www.amazon.com/Watt-Submersi.../dp/B00KLKGJ1I
Once you get further south, hot water and all that will be a distant memory...we had to put t shirts over the solar showers in Mexico..way to hot..
PS-I found that a far better use for the excess power in my system is to make ICE! All afternoon making cold drinks colder...ice cold beer, huge ice cubes for gin and tonics..I think this will become more apparent as you move to warmer climes..Nobody ever asked me for a cup of hot water..
post #46 of 66 Old 11-28-2017
misfits's Avatar
You know that would be a pretty cool idea.
IF your PV system completed charging your house bank & there were still a couple hours of good sunlight left, this would work providing your PV system had the nugget to drive a 300 watt element.
The 300 watt DC element is capable of raising the temperature in a 6 gal tank 20 degrees in an hour.
One watt equals 3.413 BTU's in my world. A 300 watt element would equal 1023 Btu's per hour.
One BTU raises the temperature of a pound of water one degree. Water weighs 8.34 pounds per gallon.
6 gallons X 8.34 X 20 degree rise= 1000 Btu's
So if you were some place that the ambient water temperature of your heater was 70 degrees, hour later it's at 90. Not a bad deal in my book.
It would also be pretty easy to make a small open loop thermal solar panel & just let it work by convection. You'd have to valve it off so at night it didn't operate the opposite way. All the above sounds like a good science experiment to me
I'm not happy unless I'm complaining about something.
I'm having a very good day!
Last edited by misfits; 11-28-2017 at 06:49 PM. Reason: can't spell after a couple of cocktails
misfits is offline
post #47 of 66 Old 11-28-2017
Master Mariner
capta's Avatar
It might be sound science in a lab, but not so much on a sailboat somewhere between 36 to 42 feet, especially in the Frisco area, as in the OP's case. You are talking about approximately 25 amps of 12 volts to get your 300 watts, sometime after peak operating hours, at which time we can assume the batteries are fully charged. With a fixed system that is at best 65% efficient in the tropics over the daylight hours, just how many panels and how much surface area are you expecting to get on a boat somewhere between 36 to 42 feet?
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #48 of 66 Old 11-28-2017
colemj's Avatar
This is the same analysis I did above, only in imperial units all the way, where I only brought it down to them at the end.
If anyone is interested in different imperial units, raising that water 20F would take 110 mile-pounds
However, your assumption of 100% solar efficiency is off. Assuming late daylight hours and non-optimal incident angle, one can really only expect ~40% efficiency from the solar. So a 300W array would only put out 120W.
Mark
- Current boat
- Previous boat
colemj is offline
post #49 of 66 Old 11-28-2017
You're putting major juice to the batts with the engine when charging the fridge - not the 170w solar. Dunno what your alternator and regulator system is...
560 worth of regular or agm batts are probably worth 170ish amps usable (not going below 50%) unless you are running the engine overtime to get them past 20% long wall of charging.
The only way you will have 'overage' solar with 240w solar will be because of engine charging.
Just a thought....
Why do you think your batts are full....what tells you that?
RegisteredUser is offline
post #50 of 66 Old 11-28-2017
colemj's Avatar
I have faith that you will rerun your math and come back to us on this...
Mark
- Current boat
- Previous boat
colemj is offline
water heater element replacement jasonr575 Gear & Maintenance 23 11-18-2013 06:48 PM
water heater stopped heating rmeador Gear & Maintenance 5 07-27-2011 11:39 AM
Boat Heating with diesel heater Petar Gear & Maintenance 3 01-09-2011 04:07 PM
solar to hot water heater? SanDiegoChip Gear & Maintenance 18 02-11-2010 05:56 PM
Diesel heater for water heating SteveCox Gear & Maintenance 1 12-13-2006 11:01 AM
