Please recommend LED replacement Bulb for Aqua Signal Series 40 Anchor Light - SailNet Community
post #1 of 5 Old 03-25-2018 Thread Starter
Please recommend LED replacement Bulb for Aqua Signal Series 40 Anchor Light.
The bulb needed is Bayonet style - "Bay 15d".
I'm looking for the brightest, best of all the brands. Please recommend a brand and a link to the source!
Thanks,
s/v Wabi Sabi
A38 #63
vpo3 is offline
post #2 of 5 Old 03-25-2018
Learning the HARD way...
eherlihy's Avatar
Re: Please recommend LED replacement Bulb for Aqua Signal Series 40 Anchor Light
Toss the fixture and replace it with this;
http://store.marinebeam.com/smart-le...be-n3-tri-cmb/
USCG Licensed OUPV Captain, ASA 101/103/104/105/106/114/118 Instructor - Also certified in Marine Electrical Systems
eherlihy is online now
post #3 of 5 Old 03-25-2018
Interestingly the led for the Aqua Signal 40 is listed on the bottom of the marinebeam product sheet.
Hudsonian is online now
post #4 of 5 Old 03-25-2018
aeventyr60's Avatar
I used this supplier:
Dr. LED Marine Lighting
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is offline
post #5 of 5 Old 03-26-2018
eherlihy's Avatar
Yes, because of the prevalence of the Aqua Signal 40 series, you can simply install the fancy LED as a retrofit. I would replace the whole fixture and thereby assure sure that it doesn't leak.
Aqua Signal Series 25 Masthead / Foredeck Navigation Light Traveling Light Electrical Systems 9 10-29-2017 06:49 AM
362 Anchor light replacement bulb? Michael Lambert Sabre 2 05-06-2017 08:45 AM
Aqua Signal series 43 nav lights VallelyJ Gear & Maintenance 2 02-01-2016 03:49 PM
Aqua Signal Toronto Conversion to LED andrewalexander Gear & Maintenance 3 07-05-2015 11:34 PM
Aqua Signal 40/50 Series LED retrifit velero Electrical Systems 8 10-06-2010 04:02 PM
