What do people use to prevent wire chafe? - SailNet Community
 6Likes
post #1 of 19 Old 04-02-2018 Thread Starter
I'm running a lot of new wire as well as reorganizing a lot of existing wires.
Some of the previous owners of this boat played it fast and loose with wire runs. Literally squeezing wires through bulkheads wherever they would fit. These are a priority for me to replace so I can properly route them to ensure they don't chafe through and cause me problems.
Again, I may be running up against my impatience with search engines, but I'm not finding a material to buy to provide chafe protection for wire (such as where it goes through bulkheads). My plan is to epoxy in a short section of PVC pipe when I make new holes, but I'd still want something to keep the wire from chafing on the edge of the pipe. The few places I've found where it seems to be done well appear to have used short pieces of rubber hose, but I'm worried that the wrong kind of hose will have reinforcing made of wire or some other material that will actually be just as bad.
What do people use for this sort of thing?
BillMoran is online now
post #2 of 19 Old 04-02-2018
Re: What do people use to prevent wire chafe?
Rubber grommets. They come in many different diameters as well as thicknesses.
seabeau is offline
The Following User Says Thank You to seabeau For This Useful Post:
BillMoran (04-02-2018)
post #3 of 19 Old 04-02-2018
Clear vinyl hose, Split it, cut to length.
Can also be used to form a grommet if the material is not too thick.
Plumbing dept at big box...
RegisteredUser is online now
post #4 of 19 Old 04-02-2018
SanderO's Avatar
Yes and no... this stuff gets brittle and shar edges of the cut hose are hardly better than the hole in the bulkhead.
Split rubber wire grommets and secure the cable with ties on both sides of the hole to stop movement from vibration.
You can also use split wire.
Split Flexible Conduit - Split Flex Tubing Manufacturer
pay attention... someone's life depends on it
SanderO is online now
post #5 of 19 Old 04-02-2018
Low pressure rubber fuel line available at any auto parts store for cheap, standard anti-short bushings from the electrical section of your local hardware store (pack of 35 is usually less than $3), chase nipples from the electrical section of your local hardware store, cut off of non-metallic conduit (deburred), shrink wrap, etc. Lots of good options out there.
https://www.homedepot.com/p/3-8-in-F...5401/100170558
https://www.homedepot.com/p/1-2-in-R...0701/100123708
SeaStar58 is offline
The Following User Says Thank You to SeaStar58 For This Useful Post:
post #6 of 19 Old 04-02-2018
Sand the pipe to remove the burs and soften the edges.
I did a major rewiring job a few years ago. My favorite method of preventing chafe was trying to eliminate the wire moving by securing it often along it's run. Then use a wire wrap for areas of abrasion concern.
https://www.cabletiesandmore.com/ame...caAicQEALw_wcB
I since discovered the split conduit Sander O posted for a truck wiring project and think it would also be great for boat wiring.
SanderO likes this.
Jordan
West Wight Potter 14 "Lemon Drop"
Oceanside CA
jephotog is online now
The Following User Says Thank You to jephotog For This Useful Post:
post #7 of 19 Old 04-02-2018
pdqaltair's Avatar
I've worked on some old boats, and I've never seen hose get hard enough to damage the wire. Any hose without wire. Tougher than split conduit.
Silicon sealant works (in addition) if you need a seal. One of the few on-boat uses.
And secure the wires.
eherlihy likes this.
Writing full-time since 2014
Author--Rigging Modern Anchors
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is online now
The Following User Says Thank You to pdqaltair For This Useful Post:
post #8 of 19 Old 04-02-2018
Learning the HARD way...
eherlihy's Avatar
+1 for SiliconE sealant. Put a glob on where the wire penetrates the bulkhead. This is one of the few uses, if not the only use, aboard.
USCG Licensed OUPV Captain, US/Sailing BKB and ASA 101/103/104/105/106/114/118 Instructor - Also ABYC certified in Marine Electrical Systems,
eherlihy is online now
The Following User Says Thank You to eherlihy For This Useful Post:
post #9 of 19 Old 12-01-2019
Dredging this up. I have used most of the solutions suggested, but it seems to me a double-flanged rubber grommet makes an ideal chafe guard. A supply of grommets like this https://www.mcmaster.com/9600k66 in 1/2" - 1.75" hole diameters would seem ideal for running wiring, plumbing hose, propane lines, etc.
But I can't seem to find them anywhere for any bulkhead thicker than electronics/aircraft/sheet metal purposes.
Thought I found a promising hint here, but it appears he's using a very thin ply.
https://lackeysailing.com/archived/k...mmets81607.jpg
90% of the bulkheads on my boat are 1/2" ply. Does anyone happen to know if and where such a thing can be sourced?
MarkofSeaLife likes this.
bajaking is offline
post #10 of 19 Old 12-01-2019
chef2sail's Avatar
I have used rubber grommets from this site when I did wire runs on Haleakula
https://www.mscdirect.com/industrial...r-grommet.html
SanderO and MarkofSeaLife like this.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
Chafe - A Cautionary Tale SanderO General Discussion (sailing related) 11 11-01-2016 01:47 PM
Bow chafe protection Minnewaska General Discussion (sailing related) 24 02-05-2016 07:40 PM
Solution to Chafe on my Genoa eherlihy Gear & Maintenance 3 06-06-2015 10:43 AM
Polyester sling for chafe control Dean101 Gear & Maintenance 21 11-04-2012 01:24 PM
Chafe gear Gene T Gear & Maintenance 8 05-13-2010 10:55 AM
