Alternator dummy help! - Page 2 - SailNet Community
 1Likes
post #11 of 24 Old 01-01-2019
bigdogandy's Avatar
Dock
Re: Alternator dummy help!
Is changing the tach to one that needs DC a possible option? Seems like that could open up your alternator options now and in the future...
Andy
Cruising
S/V Everlasting Moon
1981 Endeavour 32
Be joyful though you have considered all the facts.
- Wendell Berry
bigdogandy is online now
post #12 of 24 Old 01-01-2019
overbored's Avatar
Call these guys they know alternators https://www.dbelectrical.com/alterna...iAAEgLyEfD_BwE
"GOLD RUSH" PRINDLE 16
overbored is online now
post #13 of 24 Old 01-01-2019 Thread Starter
Bleemus's Avatar
I don't think that is an option as I believe the pulse of the AC is what you use to calibrate the rpm.
Keth
Boat Vinyl Lettering and Graphics
Bleemus is offline
post #14 of 24 Old 01-01-2019 Thread Starter
Bleemus's Avatar
Will do. Thanks.
Keth
Bleemus is offline
post #15 of 24 Old 01-01-2019
Moderator
Maine Sail's Avatar
Originally Posted by Bleemus View Post
Was a mod by PO. Current mount won't allow belt to be tensioned enough. Amptech 150a with proprietary external regulator that maxes at 14.4 but my batteries want 14.8. Their regulator failed after 400 hours. No warranty replacement. Don't want Amptech on the boat. Instead of trying shorter belt I want to simply system for easier repairs in other countries. I have an external regulator that I like that can see a max of 120a. Also have Blue Sea ACR that maxes at 120a. Both spares from previous boat that I trust. Can't use either with current alternator. Want to simplify system.
Surely there is an affordable alternator that can supply the AC I need for tach under 120a no?
The Amptech Alternator’s are well built but you can’t run a 150A alt on a single v-belt. If you have a good quality external regulator, such as a Balmar, it should be able to easily drive the 150A alt. The problem is the lack of belt to drive it not the regulator.
You don’t say what engine but there are plenty of alternator options that can drive a diesel tachometer out there. Check out the alternator section at marinehowto.com Alternators & Regulators
You could also have your Amptech rebuilt using a smaller stator / rotor combo for $200.00 or less. You’re not going to find Amptech level quality with Chinese imports such as those on DB Electric etc.. I would not be so quick to dismiss your Amptech alternator based on a bad regulator but it is too big to be driven by a single belt.
Another option would be to use a Balmar regulator, ARS-5 or MC-614 and de-rate the alt using the belt load manager feature..
Also a properly installed ACR on a cruising boat should never see more than a few amps at best running through it in order to charge the start battery.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #16 of 24 Old 01-01-2019 Thread Starter
Bleemus's Avatar
Thank you MaineSail. I believe I ordered the ACR from you awhile back as well as other items. Love my Bed-It Butyl! So even if the alternator is pumping 150 amps, even for a few seconds, the ACR would be fine even though it is rated at 120 amps? That might get me to reconsider my layout.
Keth
Bleemus is offline
post #17 of 24 Old 01-01-2019 Thread Starter
Bleemus's Avatar
Engine is a Westerbeke 55a. 495 hours.
Keth
Bleemus is offline
post #18 of 24 Old 01-01-2019
Dirt Free
boatpoker's Avatar
Am I not reading this correctly ? I'm not sure I am buying this. Convince me you have an AC alternator.
I've seen only one in 30 years of surveying.
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is online now
post #19 of 24 Old 01-01-2019 Thread Starter
Bleemus's Avatar
Well I won't profess to being an expert but my wiring diagram and the Westerbeke Service Manual says I have an alternator that puts out DC to the batteries but there is a terminal that drives the tachometer via a 6-8 volt AC feed via a brown wire. Is that highly unusual?
Keth
Bleemus is offline
post #20 of 24 Old 01-01-2019
overbored's Avatar
Common on diesel engines. the tach is connected to one leg of the 3 phase AC winding in the alternator and reads the pulses to give a read out in RPM.
Blanking/Dummy Plug Needed Altman554 Gear & Maintenance 9 12-02-2017 02:11 PM
Dinghy Dummy Jtcf78911 General Discussion (sailing related) 14 09-24-2015 08:03 PM
Installing new deck hardware for a dummy. northoceanbeach Gear & Maintenance 15 04-29-2013 11:33 AM
im a diesel dummy!! anotherfng Diesel 20 10-10-2010 06:35 AM
alternator help. hwkmoon Gear & Maintenance 1 12-26-2000 04:12 AM
