ICM203 on break for boat HVAC unit - Page 3 - SailNet Community
 3Likes
post #21 of 26 Old 02-03-2019
SchockT's Avatar
Re: ICM203 on break for boat HVAC unit
Originally Posted by SanDiegoChip View Post
I have been reading up on these but still am a little lost. Have not seen one with a timmer.
This is where the compressor is wired in the electrical box. So if we could add a timer here then set it at one min as it is being delayed by five min already then that would work?
Thanks,
Chip
Use your meter to check, but L1 (com) is probably powered continuously, and L2 is energized on a call for compressor run.
What's going on with the relay on the corner of the board? From the picture it appears that the plastic housing is melted and distorted, but maybe that's just the pic?
Sent from my SM-G960W using Tapatalk
2011 Jeanneau 39i Azura
SchockT is online now
post #22 of 26 Old 02-03-2019
overbored's Avatar
seems like the unit is cycling on and off to often. to big a unit for the load.? thermostat location to close to the air outlet? after it cools the boat why is the thermostat telling it to come back on so soon. this can happen when the thermostat is getting hit with the cold air coming out of the duct. put a pillow or blanket/towel over the thermostat and try the system
PhilCarlson likes this.
"GOLD RUSH" PRINDLE 16
overbored is online now
post #23 of 26 Old 02-03-2019
SchockT's Avatar
Yes, that is a good point, under normal conditions I would expect longer off cycle times, although if it is really hot out it could just be solar gain. Boats are not known to be well insulated.
If the controller had adjustable deadband on the setpoint, the off cycle time could be increased that way, unfortunately I dont see a configuration option for that in the manual. It is 20 year old technology...
post #24 of 26 Old 02-03-2019
overbored's Avatar
that is why I said to insulate the thermostat it acts like a dead band controller if nothing it should change the on off cycle times and you could learn from how that effects the system. slows down the reaction time of the thermostat. if it is mounted on a outside wall like the hull then this can also make it react to fast as you say solar gain. if the system works on other boats then the problem is in the particular install. so change something about the install and see what happens. block off part of the cold out and that will change the way the unit handles the heat load. if it runs all the time then you know the unit is to big for the given load. which is my guess it is winter in PV and not as much load as summer
post #25 of 26 Old 02-03-2019
SchockT's Avatar
Place a good electronic thermometer right next to the temp sensor on the control panel and watch the temperature as the system runs. If it drops rapidly then it is probably being exposed directly to discharge air, which could be as cold as 55 deg F. If that is happening then you need to divert that discharge air so it doesnt influence the sensor. Monitor the system and time how long each on and off cycle is, and how many times it cycles in an hour.
With that controller you also have the ability to add an optional remote sensor, which you can put in the return air duct. That way it should smooth out the operation and reduce the amount of cycling.
post #26 of 26 Old 02-11-2019 Thread Starter
SanDiegoChip's Avatar
Hi,
Ok, so good news!
Now, we have talked to the EasyStart™ 364 support several times during installation and they had told us at one point this EasyStart™ 364 would not fix our problem.
First we decided to test out the EasyStart™ 364 with our Mermaid Marine Air 12000 btu unit we have been having the cycling problems with. Now we have fired it up before to make sure the unit worked properly with the EasyStart™ 364 but that is far as we went then.
This time we started the unit and let it run until it reached (cooling) temperature. Then we waited for 4 min and manipulated the temperature (opened hatches and companionway doors etc ) so theA/C would cycle back on.
And then the unit came back on. It turned on the March water pump for cooling and the fan went on. The EasyStart™ 364 has a 5 min timer built in so the compressor did not come on for another minute so that worked fine. Then when the compressor came on we expected the breaker to blow because it was under six minutes. But wait, here is the good news, the breaker did NOT blow!
So we did this test several more times and our problem has gone away!
Somehow the EasyStart™ 364 did solve this problem.
We haven't done the Honda EU2000i generator test yet. When we do we will post the results.
To answer a couple of questions.
We have a 20 amp breaker, recommended size by Mermaid Marine Air.
We had tried wiring the March sea water pump to a 110 plug and plugging it into an outlet and running it separately from the Mermaid Marine Air start-up but it made no difference.
Anyway, it is working great now so the world is a better place and THANK YOU to everyone for your support.
Chip
Blog - s\v Elegant'sea
SanDiegoChip is offline
Delay-on-Make or Delay-on-Break for HVAC? SanDiegoChip Electrical Systems 4 06-14-2018 07:31 AM
HVAC Garden Hose flush WindyT Gear & Maintenance 5 12-28-2017 07:30 PM
Did I break boat buying etiquette? gigamanx General Discussion (sailing related) 30 06-09-2016 10:55 AM
How does a boat break free of its moorings?… michael.anda C25 and 250 13 03-02-2016 05:51 PM
How to size HVAC Stillraining Gear & Maintenance 5 03-17-2010 01:47 PM
