Ground on a boat? - SailNet Community
 15Likes
post #1 of 23 Old 02-28-2019 Thread Starter
krisscross's Avatar
Ground on a boat?
I am working on installing a wind generator and the manual says the tower itself as well as the third wire coming out of the generator must be grounded. I see that my boat has a thick (4 AWG?) green ground wire run to the negative main battery terminal. My boat also has a zinc saver device galvanic isolator installed which seems to be connected to the AC ground wires.
So the question is whether the wind generator ground should be connected to the green 4 AWG wire?
Your help is appreciated.
Markwesti likes this.
Plato
krisscross is online now
post #2 of 23 Old 02-28-2019
Re: Ground on a boat?
Seems logical that if it's a DC generator that it should be connected to the DC ground ... I'm guessing they mean the bonding system (i.e. the solid bare copper wire connected to all the metal parts)
Is that generator designed specifically for boats or are you using a unit designed for home use? I find it odd that they would would use that terminology, but if it's designed for marine use, maybe contact the vendor and ask for clarification?
krisscross likes this.
BillMoran is offline
post #3 of 23 Old 02-28-2019
Chassis common or reference, is often called "Earth Ground", but it isn't in any mobile context.
True Ground is pounding a rod deep into moist soil, with some geology need to go way down.
Electricians experienced in high-voltage Floating systems where gear really is supposed to be Earthed are relatively rare.
But well under 48V and DC only, using chassis common is likely good enough, at least unlikely to be fatal if you screw up.
Don't feel reassured by that? Get in a pro to at least check your plan and inspect the result afterwards, if not actually do the work.
john61ct is online now
post #4 of 23 Old 02-28-2019
Markwesti's Avatar
The ground (earth) wires on my boat are black . My ground starts at the engine block .
https://www.emarineinc.com/Grounding...tems-On-A-Boat
https://www.emarineinc.com/Grounding...ms-on-a-Vessel
Westsail 28 , Patricia A
Markwesti is offline
The Following User Says Thank You to Markwesti For This Useful Post:
krisscross (02-28-2019)
post #5 of 23 Old 02-28-2019 Thread Starter
krisscross's Avatar
Its an AirBreeze generator very much marketed for marine use. There is a section devoted to installation on boats but rather vague. My boat does not have a bare copper wire or strip. Just green wires grounding to the negative terminal on the battery bank.
Plato
post #6 of 23 Old 02-28-2019
Dirt Free
boatpoker's Avatar
Transport Canada “Constructions Standards For Small Vessels”, TP1332E and ABYC "AC and DC Electrical Systems On Boats" Standard E-11 require that AC and DC grounds be bonded and show a resistance of less than 1ohm.
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is online now
post #7 of 23 Old 03-01-2019
bigdogandy's Avatar
Dock
Kriss - follow the big black cables from the battery to where they terminate. Should be on the engine block, or a large bus bar that connects to the engine block. That’s your ground.
It is most likely a bad mistake to connect to the green wires. Those are usually either for AC grounding or for bonding metal through hulls together (unless a previous owner did something creative with green wire!) and in either case are dangerous to rely on as a ground for any DC system.
I learned the hard way on this kind of thing, and really wish I had gotten a qualified marine electrician to do the work and educate me along the way.
Be careful.
Andy
Hard Aground
S/V Everlasting Moon
1981 Endeavour 32
Be joyful though you have considered all the facts.
- Wendell Berry
bigdogandy is online now
post #8 of 23 Old 03-01-2019 Thread Starter
krisscross's Avatar
What exactly does it mean bonded? Are the AC and DC grounds supposed to be connected to the same thing?
Plato
post #9 of 23 Old 03-01-2019 Thread Starter
krisscross's Avatar
Yes, that 4AWG green wire connects to the black cable bus bar next to the engine block and connected to it.
Plato
post #10 of 23 Old 03-01-2019
Dirt Free
boatpoker's Avatar
Originally Posted by krisscross View Post
what exactly does it mean bonded? Are the ac and dc grounds supposed to be connected to the same thing?
yes !
12V ground on the boat Frogc Electrical Systems 23 07-26-2016 11:50 PM
SSB Ground - Any Dynaplate Users? Cap'nJeff Gear & Maintenance 30 07-11-2011 10:25 AM
Role of engine in DC "boat ground potential" floatsome Electrical Systems 19 04-12-2009 05:22 AM
SSB Ground and SSB vs. Ham joseph53p Gear & Maintenance 9 02-09-2001 06:13 PM
Ground for AC System fesivo Gear & Maintenance 1 01-23-2001 09:47 PM
