Realistic expectations for my house batteries - Page 11 - SailNet Community
 25Likes
post #101 of 138 Old 04-16-2019
bell ringer
Don L's Avatar
Re: Realistic expectations for my house batteries
AGM take charge more quickly than wet.
Never require constant filling with DISTILLED water ( hidden expense and again time and effort) AGM you don't sorry about battery acid leaking.
Let first say that I don't care what type of battery people what to use on THEIR boat and don't understand why so many seem to. So many batteries choice threads are people looking to prove their decision was correct to justify whatever it was. Get the batteries you like and move along.
But far as charge acceptance
- except a fairly highly discharged battery the acceptance of AGM is not much a plus. I wonder just how often AGM owners ever put in more than 25% as current/20 hr capacity into their batteries??? I bet most don't even have a charge source that could.
water/acid
- I water my FLA batteries 1/month and it takes about 10 minutes. The 4 of them normally take about 2 cups of water. That probably works out to about $0.50/mo. I wouldn't call that "constant filling" or much of a hidden expense
- I never have ever worried about my batteries acid "leaking"
If you want to use agm, gels, lithium, or whatever batteries on YOUR boat go ahead. They are just batteries, they are met to be used, abused, and replaced when needed.
Don't blow air up my rear, be useful and blow it at the sails!
Don L is online now
post #102 of 138 Old 04-16-2019
hpeer-
If you are US born, the helpful folks at Social Security say that since you've made it to age 65 you will very probably live to age 86. So...you know, getting 20 years on the next set might not be such a bad idea. One less heavy thing to move around when you're 86.(VBG)
chef-
I'm an AGM fan as well, mainly because I got tired of replacing acid-eaten cloths. Factor in the cloths and maybe some carpet or other fabric, and the AGMs become cheaper than wet lead.
But I think your case of AGM vs wet lead is a bit skewed. You've gotten excellent but exceptional life from your AGMs, indicating a good charging system. Some folks have also reported 8-10 years from Rolls, Surette, and other top quality wet lead batteries. Most folks report half of that, regardless of battery type, so how you are maintaining them is more likely the reason for the great longevity.
And of course being sealed and needing no water is great--except, that gives you no ability to add water if there's been overcharging for any reason. That's a double-edged sword. The distilled water itself is trivial. 94c per gallon at WalMart, $1.50 at any supermarket in the laundry aisle if it isn't with the water products. If you need to top up frequently, that's again just a charging problem, not the battery's fault. (And how many charging systems are temperature compensated, or designed for marine use instead of cars, at all?)
In exchange for that, wet lead will be about 1/3 cheaper than AGM. Ignoring the cost of the inevitable acid eaten clothing.(G) So, not so bad for everyone, just not the right solution for all of us.
MastUndSchotbruch and mbianka like this.
hellosailor is offline
post #103 of 138 Old 04-16-2019
Originally Posted by hpeer View Post
So what would one recommend to replace 4-GC2 Lead Acid batteries. My batter box is built to EXACTLY fit the 4 GC2 batteries, so I’m stuck with that size format. .
If you’re happy with them, why not replace in-kind? Do you want something new?
They’re 6v, if I’m not mistaken. I suspect two 12v batts could fit where your four 6v live today. Usually that would lower your capacity, in similar footprint, but I haven’t checked dimensions. It doesn’t sound like you want to spend the money for the weight, capacity and charge advantages of lithium.
Keep in mind, if you change to anything other than flooded wet cell, you’ll need to modify all your charging systems.
Jeanneau 54DS
Minnewaska is offline
post #104 of 138 Old 04-16-2019
hpeer's Avatar
When we bought the boat ONE of the minor things the surveyor missed was the batteries were stuck in the bilge, not in a box, not secured in any way, and not even flat.
The bilge wasn’t working so I made a box under the nav table seat. It takes the 4 GC2 batteries arranged with one long and one short dimension on a side. It is not “tight” and there is a bit of a hole in the middle but it is a very compact arrangement. It’s a bit hard to describe the arrangement, but they do not lay side by side, or end to end. It’s not ideal, but it’s what I have.
My “charging arrangement” is two solar panels each with an MPPT controller, both panels charge the bank, a wind generator through charges the bank and has a divert load, the engine which goes through a charge isolator so it charges both the house and start batteries, and a Honda generator with a very old school heavy 12VDC charger, it puts out 50 amps and will get the batteries to about 15.5 V. The charger is not hooked up. When I want to use it, very infrequently, I clamp it onto the batteries and plug it into the generator. If it dies I’m out $150 (it’s not “Marine”, it’s not “smart”).
33' Brewer, Murray 33, steel cutter
44' Pape, Steelmaid, cc steel cutter
hpeer is online now
post #105 of 138 Old 04-16-2019
colemj's Avatar
Distilled water is not trivial outside the US. It is not only very difficult to find, it is also very expensive when you can find it. The most common form is sold in quarts at automotive and marine specialty stores as "battery water". This is yellow in color, and I can only guess it is distilled water, although it says it is "filtered for purity using state of the art equipment". Frankly, I think our watermaker probably makes this stuff in a non-yellow form.
https://www.islandwaterworld.com/bat...d-prix-mi80002
Note that that is a very good price for this. I've paid $5-6 per quart in Panama and Guatemala.
While I loved our FLA banks, and think they are the best bang for the money, and that maintaining them is over-emphasized, I did find them to be a pain outside the USA. I would stock 5 gallons of distilled water when I could find it. That was 50lbs and filled the same space as the batteries themselves.
If you have new FLA's, then you won't be needing much water. As they age, they become quite thirsty. Owning older FLA's in Panama becomes a challenge at time for the silly fact of water...
Mark
Dolphin 460 Catamaran "Reach"
- Current boat
- Previous boat
colemj is offline
post #106 of 138 Old 04-16-2019
The fla 'auto waterung' systems seem to me as a problem...that will arise.
Plumbing
RegisteredUser is online now
post #107 of 138 Old 04-16-2019
colemj's Avatar
We just sold a nice FLA bank with an automatic watering system. For the 3 months I used it, that watering system was really nice. Definitely worth the cost if you have FLA. I balked at it in the past because it isn't too difficult to maintain FLA's, but I must admit it is ridiculously nice to just occasionally squeeze a bulb whenever you think about it and have all of the battery cells get exactly the right amount of water without ever removing the caps. Could probably even hook it up to a pump with an adjustable pressure switch to be truly automatic.
Mark
- Current boat
- Previous boat
colemj is offline
post #108 of 138 Old 04-16-2019
bell ringer
Don L's Avatar
There ways to get pure water for a battery besides distilled. I was in water treatment and carried a bottle of ion exchange resin with me that made basically pure water from tap water
Don L is online now
post #109 of 138 Old 04-17-2019 Thread Starter
SchockT's Avatar
That is one seriously incompetent surveyor! How does a surveyor miss such a serious problem? That's the kind of thing that even the volunteer "Courtesey Safety Inspectors" look at when our club does annual safety inspections!
Sent from my SM-G960W using Tapatalk
2011 Jeanneau 39i Azura
SchockT is online now
post #110 of 138 Old 04-17-2019
hpeer's Avatar
Well, he also missed the fact that the bilge pump (not functional), was under the muffler, which was under the drive shaft. In order to change the bilge pump you had to haul, pull he shaft, remove the muffler; THEN you could change the bilge pump.
I could go on, Ive seen a couple like this.
hpeer is online now
Thoughts on whether I should relocate my house batteries ... BillMoran Gear & Maintenance 16 12-27-2017 05:59 PM
Realistic to get my first keelboat for under $10K? aaronwindward Boat Review and Purchase Forum 38 09-21-2010 04:33 PM
Great Expectations HoffaLives Boat Review and Purchase Forum 26 03-15-2007 09:23 PM
Realistic Expectations openseas1960 Cruising & Liveaboard Forum 9 03-14-2006 02:37 PM
Realistic Expectations openseas1960 Living Aboard 6 02-23-2006 05:03 PM
