Realistic expectations for my house batteries - Page 13 - SailNet Community
 25Likes
post #121 of 138 Old 04-21-2019
outbound's Avatar
Re: Realistic expectations for my house batteries
Boat was on the hard for 6 months of the last 6 years. Got it with flooded lead. Immediately changed to agm. They get of to 100% regularly. Very rarely below 80%. If switched to Li would need to glass in pb to keep trim. Carbon foam is still on back order from most places so premium cost with no discounts at present. Hopefully will change by the time I need to re up on batteries. Please understand Li remains a possibility. With review the calculus when the time comes. Have several friends who switched to carbon and are quite pleased. At time of purchase carbon was cheaper then Li Ah to Ah. Expect that will return as production increases to demand.
This year while in the windwards wake up to batteries being at 13.1-13.4. During the day solar is frequently diverted to heat sinks. In this setting don’t get to exploit the numerous advantages of Li. Even wondering if pb may suffice if we continue to stay in this cruising grounds.
s/v Hippocampus
Outbound 46
outbound is online now
post #122 of 138 Old 04-21-2019
outbound's Avatar
https://www.morganscloud.com/2018/05...art-1-lithium/
Nice short review worth reading before blowing the bucks.
s/v Hippocampus
Outbound 46
post #123 of 138 Old 04-21-2019
colemj's Avatar
Your only two choices are lead or lithium. Carbon foam is still a lead acid battery no different in chemistry than all other lead acid batteries.
That link goes to a paywall, so can't read the article. However, one should take Morgan's Cloud writings with a grain of salt. They have been seriously wrong, or uninformed, on several things in the past, and sometimes confuse their celebrity with expertise.
If you really want to read up, we have a resident here - Mainesail - who has done some very good work and communication about lithium batteries in boats. There are also great threads and blogs written by people similar to Mainesail who have also done a lot of hands-on experimentation. I would go to these places before Morganscloud for gaining knowledge in this area.
Mark
Dolphin 460 Catamaran "Reach"
- Current boat
- Previous boat
colemj is offline
post #124 of 138 Old 04-21-2019
outbound's Avatar
Different strokes for different folks. What impresses me with Morgan cloud is when wrong they fess up and publish a correction. Their readership is quite vocal in letting very little slide and consists of many long term cruisers.
Always look forward to Mainesails input.
s/v Hippocampus
Outbound 46
post #125 of 138 Old 04-21-2019
MS LFP post https://marinehowto.com/lifepo4-batteries-on-boats/
mbianka likes this.
john61ct is online now
post #126 of 138 Old 04-22-2019
Originally Posted by john61ct View Post
After reading Maine Sails treatise on lithium versus AGM batteries until my brain hurts. I'm more convinced than ever but I made the right choice to just stick with AGM batteries for my boats electric propulsion system and Gels for the house battery bank. Adding the complexity and cost of the lithium system just does not make sense for my sailboat.
MarkofSeaLife and john61ct like this.
Mike
Currently: Heading to warm waters over the winter on a variety of boats.
mbianka is online now
The Following User Says Thank You to mbianka For This Useful Post:
john61ct (04-22-2019)
post #127 of 138 Old 04-22-2019
Super Moderator
Maine Sail's Avatar
For many boaters use/applications LFP does not make financial sense unless you plan to DIY then the cost is comparable to AGM..... For many who want to DIY they often don't make smart sense because too many folks don't care to do the research and ruin them far too early.
Still my own 400Ah cells are now 10 years old and they still deliver in excess of 400Ah with over 1100 cycles on them. Other than Firefly I can't think of more than a couple of lead acid batteries we've tested, at more than a year old, that could deliver their full Ah rating. Just two weeks ago we had a customers West Marine / East Penn AGM's in the shop for testing. At 16 months old they could only muster 61% of their rated capacity (technically dead in less than 16 months)... Ouch!!!
At this rate I fully expect our bank to last at least 15 years but perhaps even 20 or more.
Considering it cost us less than a bank of Odyssey TPPL AGM's, that would have long ago been dead, the value for us was certainly there even though we only use the boat for 6-months each year. There are also other hidden benefits, since installing LFP I've not once had to dig into the Espar, to clean it, where with LA it was literally an every spring ritual.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #128 of 138 Old 04-22-2019
My first set of AGM's for my Electric Propulsion system lasted eight years. Actually only one of the batteries got flaky due to a parasitic load that was on it over the winters. I think I could have gotten 10 years out of the bank otherwise. I replaced them all since they were eight years old just to keep the ages the same.
With the second set I made a big mistake. Of the four batteries shipped two arrived in a visibly damaged condition. They were replaced by the shipper but, I should have rejected all four because the next season one if the other batteries failed after a short amount of time in operation. This season I will be replacing only that one since the others are still fairly new. I expect I'll get close to ten years out of the current bank if the past is any indication. Hopefully by then Lithium prices will have lowered and the batteries become more plug and play than they currently are. But, I said the same thing when I initially converted to Electric Propulsion in 2008.
Not sure why a difference between Lead Acid and Lithium batteries would affect you Espar heater?
Mike
post #129 of 138 Old 04-22-2019
SanderO's Avatar
My first pair of 8D AGMs lasted 8 years... did not have a separate start battery... OEM one two both switch. upgraded system... blue seas 8080 swtich.. optima blue top start... paralleled 2 AGMs for house bank... upgraded regulators added ech charge and link 20 monitor... changed to all LEDs. 7 years... and they seem fine. I expect them to expire within the next couple of years.
pay attention... someone's life depends on it
SanderO is online now
post #130 of 138 Old 04-22-2019
chef2sail's Avatar
Our first set of 6-6volt lifeline AGM lasted 10+ years with very little loss till the end. Even the we probably could have eeked another year but because of our extended vacations on the hook decided to replace. The 720 ah bank is overkill for us, but I really don't want to have to sorry about power. 6 volts are easy for me to handle myself . We can fit 6 into the space . We have a blue top spiral starting battery. We do equaluze the Lifelines monthly to prevent premature suffication.
For our usage they have fit the bill and are very low maintenance.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
Thoughts on whether I should relocate my house batteries ... BillMoran Gear & Maintenance 16 12-27-2017 06:59 PM
Realistic to get my first keelboat for under $10K? aaronwindward Boat Review and Purchase Forum 38 09-21-2010 05:33 PM
Great Expectations HoffaLives Boat Review and Purchase Forum 26 03-15-2007 10:23 PM
Realistic Expectations openseas1960 Cruising & Liveaboard Forum 9 03-14-2006 03:37 PM
Realistic Expectations openseas1960 Living Aboard 6 02-23-2006 06:03 PM
