Cube Fuse on a Distribution Bar - SailNet Community
 2Likes
post #1 of 13 Old 04-10-2019 Thread Starter
Question Cube Fuse on a Distribution Bar
Looking at the MRBF fuses available I'm trying to understand why a fuse block is used instead of simply mounting it directly on the power distribution bar. An insulating shoulder washer would be needed, of course, but how would it be any different than using the stud on the block?
I also wonder at the price spread. Less than $9 to more than $18 for brand name fuses.
nramsey is offline
post #2 of 13 Old 04-10-2019
colemj's Avatar
Re: Cube Fuse on a Distribution Bar
Are you talking about these: https://www.westmarine.com/buy/blue-...09_273_007_517
If so, they are common.
Mark
Manta 40 Catamaran "Reach"
colemj is offline
post #3 of 13 Old 04-10-2019 Thread Starter
Yes, that's them. My question is why would you need to use the block:
https://www.bluesea.com/products/519...k_-_30_to_300A
Couldn't you save money and space just putting them onto the bus bar, or even bolted down to the battery terminal without the fuse block?
nramsey is offline
post #4 of 13 Old 04-10-2019
kenr74's Avatar
The stud is isolated from the base. Otherwise the blown fuse would not break the circuit.
CVAT likes this.
kenr74 is online now
post #5 of 13 Old 04-11-2019
Are you asking whether you can put the fuse at the positive distribution bus, rather than on the battery itself? If so, I understand the fuse must be less than a max distance (inches) from the battery and the bus is likely far beyond that. Not to mention, some banks have other systems, such as bilge pumps, that by-pass the bus and are wired directly to the bank.
CVAT likes this.
Jeanneau 54DS
Minnewaska is offline
post #6 of 13 Old 04-11-2019 Thread Starter
I'm thinking of using the cube fuses on the +ve bus as branch fuses for the various fused wires such as the alternator, starter, solar, bilge pump etc. The battery would still be fused at the post but I still don't understand the need for the extra fuse block. If you insulate it properly it would still fuse the circuit.
Cube Fuse on a Distribution Bar-positive-battery-terminal-clamp-ceramic-cube-fuse-vehicles-boats%5B1%5D.jpg
This picture is what started my thoughts. Imagine the stud as a stud on the positive bus bar. Why would you need the extra fuse block?
It adds connections that I don't see as doing anything.
nramsey is offline
post #7 of 13 Old 04-11-2019
Originally Posted by nramsey View Post
...This picture is what started my thoughts. Imagine the stud as a stud on the positive bus bar. Why would you need the extra fuse block?
That setup in the pic looks wrong. Nothing is actually being fused. The cable is still in contact directly with the stud. Those cube fuses need to have a standoff that the cable is connected to. I may not be following the question.
Jeanneau 54DS
post #8 of 13 Old 04-11-2019 Thread Starter
I don't think so. The nylon shoulder washer will keep the cable from contacting the stud.
nramsey is offline
post #9 of 13 Old 04-11-2019
kenr74's Avatar
Perhaps a picture will help. There is no continuity between the base and the stud. In other words there is an open circuit between the two probes.
post #10 of 13 Old 04-11-2019 Thread Starter
I understand that, but the insulator on top does the same job. The stud is not connected directly to the cable. The current must go through the fuse. Just "upside down" but with the same result.
Insulating the stud from the base is more difficult than insulating the cable from the stud but I can't see any difference in the result.
nramsey is offline
cube fuses deniseO30 Electrical Systems 2 06-25-2014 10:40 AM
the "cube" deniseO30 Diesel 0 04-15-2014 11:16 AM
Lighting Rubic's Cube i_amcdn Gear & Maintenance 8 05-14-2013 08:51 AM
vertical ice cube tray cbayermd Gear & Maintenance 21 01-08-2012 07:48 PM
Fuse size for fuse panel? SanDiegoChip Electrical Systems 34 10-31-2010 12:22 AM
