Are my batteries shot? - Page 2 - SailNet Community
post #11 of 17 Old 05-14-2019
Re: Are my batteries shot?
Yes, the Victron stuff is very good, but still with all gear the owner needs to adjust Absorb Hold Time, not just accept defaults, verify endAmps is actually being reached at Absorb before sources are dropping to Float
john61ct is online now
The Following User Says Thank You to john61ct For This Useful Post:
BillMoran (05-14-2019)
post #12 of 17 Old 05-14-2019
Bleemus's Avatar
The Victron can be set to a 12 hour absorption hold time but will go to float when end amps hits 2A no matter how you set it if I recall correctly.
Keth
Boat Vinyl Lettering and Graphics
Bleemus is offline
post #13 of 17 Old 05-15-2019
So **if** you need to go longer, just put a small constant load on, it has no way of knowing what portion of current is actually being accepted.
Or just restart to get another cycle with the minimum AHT.
But really I doubt such kludges are often needed in practice.
post #14 of 17 Old 05-15-2019
It's pretty unlikely one has enough solar real estate, not to mention a long enough and bright enough day, to over charge a house bank. That's likely why a timer works okay on these, as they never really time out. The charge just peters out at dusk. However, I still find it highly suspect that the bank is getting anywhere near truly full.
Jeanneau 54DS
Minnewaska is offline
post #15 of 17 Old 05-15-2019
Well whether or not that is the case can be easily verified objectively, no need for guesswork
And if indeed in a given context the solar never stands a chance of getting the bank to Full, then just set Float to the Absorb spec.
Just remember to set it back if / when that context changes.
post #16 of 17 Old 05-15-2019
Originally Posted by john61ct View Post
Well whether or not that is the case can be easily verified objectively,......
I agree. With a shunt. Is there a solar controller that uses one?
Jeanneau 54DS
post #17 of 17 Old 05-15-2019
Yes, but with any charge source, using any ammeter at the bank, is what I meant.
Is my Inverter/Charger Killing my Batteries, or Vice Versa? MarkSailor Electrical Systems 4 11-05-2017 08:44 AM
Oh my god oh my god oh my god oh my god... cthoops Boat Review and Purchase Forum 26 04-16-2013 07:48 PM
I'm getting my shot tonybinTX General Discussion (sailing related) 42 11-21-2008 02:35 AM
Sling Shot wins second Three Peaks (Australian Broadcasting Corporation) NewsReader News Feeds 0 04-17-2006 12:15 PM
Oh my God! My brother shot me in the arm! Bro-ofasailer General Discussion (sailing related) 3 03-16-2003 06:36 PM
