Any particular brands of AGM batteries to avoid? - Page 2 - SailNet Community
 7Likes
post #11 of 31 Old 05-18-2019
Re: Any particular brands of AGM batteries to avoid?
Yes 7 years is a good run for those. What % of days per year did they get cycled as opposed to sitting at full?
How deep you reckon the avg discharge on cycling days?
Note EoL standard is at 80% SoH, you could have passed that years ago not even know it without doing a 20-hour load test benchmark.
john61ct is online now
post #12 of 31 Old 05-18-2019
SanderO's Avatar
The batts don't do deep cycles. My batts are generally kept pretty topped up... because they are charged by 110 watts of solar. When voltage does drops indicating they are becoming discharged I will run the engine which has a balmar 614 and a 125 amp alternator. I watch the alts in and when it drops to about 10 amps I usually stop the engine ...unless we need it for propulsion. Never on shore power. Refer is an engine drive so typical sailing day we motor off the mooring/anchor get the sails up and kill the engine and sail. End of the day is reverse. Sometimes we motor sail.. so we are cooling the refrigerator, making hot water and topping off the house bank. All lighting is now LED so that helps a lot too
pay attention... someone's life depends on it
SanderO is online now
post #13 of 31 Old 05-18-2019
Originally Posted by SanderO View Post
.....I watch the alts in and when it drops to about 10 amps I usually stop the engine.....
Your pic shows 2x8D batts, which I'd estimate is approx 450 Ahrs? If correct, 10 amps is a very long way from topped up. Probably wouldn't even go to Float until something in the range of 2-4 amps.
I totally understand why you would stop burning diesel, as the further up the charge curve you get, the slower the charging rate. I'd do the same, when off the dock.
It doesn't seem like you have significant solar either, so the fact that your batteries do so well is interesting. I suppose it could be the very low usage. Essentially zero load, while you're away, right?
Jeanneau 54DS
Minnewaska is offline
post #14 of 31 Old 05-18-2019
SanderO's Avatar
We don't use much power... none during the week when we're not aboard. Bilge pump is it.
Sailing during the day we have instruments and the AP.
In the evening sailing... rare... we add nav lights, some cabin lights maybe radar
At anchor mooring we splurge...NUC computer and monitor (buck 19 transformer... some lighting.
And the water pumps or the shower pump... not a lot
if it's cold the Espar is used and it sucks some decent amps.
and some USB charging and charging power tool batts (done when motor/inverter is on)
post #15 of 31 Old 05-18-2019
Yes, if barely cycled, any battery will last 10x or more life cycles compared to the normal 40-60% Dod.
In fact calendar life, as if stored on a shelf topped up every couple months,
ends up a greater factor than the avg-DoD vs cycle lifetime chart.
In that scenario, true not worth paying extra for a quality deep cycling bank, and the data from that usage pattern is irrelevant to true deep cycling use cases.
But then the Duracell / Deka don't actually cost any more than the big-box or Amazon pseudo dc units anyway.
In those conditions might last thirty years as opposed to the usual 6-8.
Or you could get by with the little $20 versions 8-)
post #16 of 31 Old 05-18-2019
fallard's Avatar
FWIW my Trojan AGMs are starting their 10th year and seem to be holding their own.
sailforlife likes this.
fallard is offline
post #17 of 31 Old 05-19-2019
Geoff54's Avatar
I would avoid Optima since they are now made by Johnson Controls. I have used Optimas in several applications over the years and been very happy with them. I installed one as a starting battery in 2005 and, despite being abused because of a phantom load which took forever to identify, it lasted until 2017. I replaced it with the "same" and, only after purchase realized that it was no longer made by Enersys. After a little over two years it would no longer hold a charge. Just one data point but I just replaced it with an Odyssey which is the current Enersys brand - fingers crossed.
"The great thing about the internet is that you can quote anyone and no one will bother to check the source" - Aristotle
Geoff54 is offline
The Following User Says Thank You to Geoff54 For This Useful Post:
BillMoran (05-19-2019)
post #18 of 31 Old 05-19-2019
outbound's Avatar
Like my lifelines. Just load tested and all passed after 5 1/2 years of full time cruising. Starter didn’t but that’s because they were over charged when I think Cove haven marina in barrington r.i. missed wired a genset.
Know some people are weight and space sensitive. Some have multiple high draw demands. Others are quite concerned about service life. Personally high quality AGMs were worth it for us. Carbon will be the next set although. But now see WM is selling flooded batteries which won’t spill acid out of the housing if tipped over. Interesting concept and at that price point well maybe a good choice for many.
s/v Hippocampus
Outbound 46
outbound is online now
post #19 of 31 Old 05-19-2019
Yes Optima are fine as Starters, not true deep cycling anymore
post #20 of 31 Old 05-19-2019
Geoff54's Avatar
I think that you misunderstood. This is/was a starter..... and it was junk.
Geoff54 is offline
Bilge paint: any brands to favor or avoid? BillMoran Gear & Maintenance 22 05-28-2018 09:06 PM
how do I respond to particular posts, including mine? and how do I quote particular r seaphrogg SailNet Website Technical Support 10 05-07-2018 01:40 PM
Any advantage/disadvantage to registering a boat in a particular state? Sleddriver General Discussion (sailing related) 18 11-16-2015 07:44 PM
AGM Battery brands - any feedback? pshearing Electrical Systems 8 08-12-2009 05:52 PM
Mixing different AGM sizes and brands voice3 Gear & Maintenance 4 06-01-2009 12:05 PM
